Stupid tire pressure question...
Old Jan 20, 2008 | 02:42 AM
dhays's Avatar
I put new rims and tires on my FD. 18x8.5 ET40 with 235/40R18. (There was a reason I went with the relatively narrow 235mm btw although I know many of you will say I should have gone much wider.)
My question is about what pressure to run the tires at. Mazda recommended 32psi for the stock 225/50R16s. What pressure should I run these new tires at?
Old Jan 20, 2008 | 08:06 AM
Mahjik's Avatar
Mr. Links
30-32 is fine for the street.
Old Jan 20, 2008 | 10:02 AM
cewrx7r1's Avatar
Eye In The Sky
Basic tire pressure will vary depending on tire load and tire size. A tire with more internal volume should use less pressure. A tire with less internal volume should use more pressure. To be in the ball park, contact the tire manufacturer
My rims are 9X17. When I went to 245/40-17 front and 275/40-17 Yokohamas, I contacted them about their recommended pressure for my car. Based upon the FD weight and weight distribution, they gave me this starting point: 34 front and 26 rear. It works great for the street.
Old Jan 20, 2008 | 10:24 AM
dgeesaman's Avatar
I suggest you stay with the Mazda tire pressures.
Dave
Old Jan 20, 2008 | 01:50 PM
dhays's Avatar
Dave
That is what I've done, but I was just wondering about the very issues that cewrx7r1 mentioned. I think contacting the manufacturer is a good idea.
Thanks guys.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
elfking
Aug 19, 2015 09:48 PM
bb6guy
Aug 12, 2015 03:29 PM
