i think its time for a custom TID
Old Apr 18, 2002 | 09:48 AM
vosko's Avatar
Just Call Me Terminator!
Wink i think its time for a custom TID
i went to the track last night. i had no luck. first launch boom TID pops off car is dead in the water. i get pushed over pop it back on. go back second run same thing. i take off the TID. it previous had two little cracks on the end where it goes on the turbo compressor inlet when we put on the new turbo. when i checked it at the track the two cracks were gone along with the rubber judge ito came and cut off the other side but it still kept popping off. i just drove it home and it popped off twice. i unbolted the afm and its been somewhat ok but i'm not gonna risk that happening again! i think its time to goto home depot and make a custom TID with a better clamp any idea's or suggestions i know the guy on partstrader is selling one but i'm not paying $150 for it
Old Apr 18, 2002 | 09:57 AM
TonyTurboII's Avatar
Glock Lover
Custom TID's OWN.
Old Apr 18, 2002 | 11:30 AM
vosko's Avatar
i guess i'll check ted's page
Old Apr 18, 2002 | 11:32 AM
Grimlock's Avatar
once i did mine i notcie a nice difference...she pulls better now next best thing to getting rid of the afm altogether! e6k here i come!
i found an intake pipe on the highway (just under 3in.) with a 45 degree bend. i cut it down and got some connectors from home depot. i wish i wouldve done the tid sooner but hey it only cost me $10 this way. get a 3in. aluminum pipe and cut to fit.
Old Apr 18, 2002 | 11:33 AM
MaxRX7's Avatar
hambre y sueño
home depot car parts !!!
Old Apr 18, 2002 | 01:16 PM
Ryde _Or_Die's Avatar
I want to make a custom one out of PVC. Is there a write-up of how to do this? Like what fittings I would need and what size works? Pics would be great. Thanks.
Old Apr 18, 2002 | 01:27 PM
j9fd3s's Avatar
Community Builder
i had 2 home depot boots with a 45 degree pipe on mine, or you can do it the seth way and put the afm right on the turbo....
mike
Old Apr 18, 2002 | 01:42 PM
vosko's Avatar
hmm, AFM on the turbo, interesting i still have stock bov and those vacuum lines. i'm still in the pondering stage about this
Old Apr 18, 2002 | 02:14 PM
Josepi's Avatar
Despise Enmity
I'd worry about the AFM being too close to all the heat generated. Don't use PVC either, just have an exhaust shop mandrel bend you some 2.5-3" exhuast to your own specs. It'll cost you about 10-15 bucks, last longer, and is polishable.
Old Apr 18, 2002 | 02:58 PM
Is there something wrong with using PVC? I use it daily for work so it would be easy for me to do myself. I was going to make it myself and then paint it with some engine enamel and clear coat.
Old Apr 18, 2002 | 03:06 PM
Erik's Avatar
Best of both worlds
Originally posted by Grimlock
[B]
i found an intake pipe on the highway [B]
LOL...that rules
Old Apr 18, 2002 | 03:09 PM
vosko's Avatar
i have an e6k at the shop but it's not going in my TII
Old Apr 18, 2002 | 03:17 PM
Josepi's Avatar
Despise Enmity
I think there was a thread on this last week about using it for IC piping. Plastics are heated and can release corrosive gases. That's why you never see any PVC bongs for sale anywhere.
Old Apr 18, 2002 | 03:38 PM
Grimlock's Avatar
any suggestions on where i should get the e6k from. i wanna know if theres any place cheaper than rotary performance?
im gonna throw that baby in my 88TII daily driver
Old Apr 18, 2002 | 03:42 PM
Felix Wankel's Avatar
Super Newbie
And you just said the other day that you don't need a TID.
Old Apr 18, 2002 | 03:46 PM
NZConvertible's Avatar
I'm a boost creep...
Here's something I posted a little while ago, it's a description of what I did to my last car:
My last was a 1984 Mazda Cosmo, complete with factory 12A Turbo. The airbox/AFM/TID/turbo setup was almost identical to the FC RX-7. I replaced everything except the AFM.
I replaced the TID with a Ø2.5" 45º mandrel bent steel tube about 10" long (nice swept bend) which I had flared up to 3" at the AFM end and HPC coated (just for looks), this was coupled to the turbo and AFM with rubber couplers and hose clamps (I didn't have a BOV so no connection was needed). I made a bracket (also HPC'd) to support the AFM. I replaced the airbox with the biggest K&N pod filter I could fit (3" neck), and made a cool little stainless steel square-to-round adapter to fit it to the AFM (I've got a cast HKS one on my FC). The pod filter was isolated from the engine bay with an aluminium shield and fed cold air from a 3" scoop under the bumper. The performance increase was huge (especially when you consider it cost stuff-all because I made it all myself) and it looked really trick. As soon as I get my FC's wastegate ported, this is exactly what I'm going to do, because I know how well it works.
BTW, personally I wouldn't use PVC, I think it looks cheap and nasty!
Old Apr 18, 2002 | 03:51 PM
flying taco's Avatar
Rock Star.... almost
****... i thought that pot was a little harsh... *Note to self* Don't use the homemade water bong anymore.
Old Apr 18, 2002 | 04:15 PM
vosko's Avatar
right now www.k2rd.com is the cheapest. i bought mine from rx7.com only paid like $1500 at my door
vosko's Avatar
i just said that cause i'm lazy
Old Apr 18, 2002 | 04:24 PM
Super Newbie
Get that catback, boost controller, and TID on and go kick some ***.
I'm leaving in about 10 minutes to see what my car will do (1/8th mile tonight).
Old Apr 18, 2002 | 07:59 PM
vosko's Avatar
ok i now have ITO-SPEC TID. so much more torque in first and second gear damn pos stock TID. a little more boost too. silver93tt and i found an old charge pipe from something. even had the right reducer on it! i will have pix tomorrow its too dark
Old Apr 18, 2002 | 08:09 PM
What the hell's that?
Old Apr 18, 2002 | 10:55 PM
Super Newbie
Judge Ito.
Hey Vosko, my stock IC was heat soaking like a bitch today. My car was running like *** at the track from having to wait in the staging lanes in 76*+ weather.
Old Apr 18, 2002 | 10:57 PM
vosko's Avatar
Judge Ito.
mine was too yesterday didn't matter cause i didn't run. buy a bag of ice for the intercooler when you go. makes a HUGE difference. what did you run. if you ran 8.9 in the 1/8th that is a 13.9 1/4
Old Apr 18, 2002 | 11:00 PM
Super Newbie
My car melted the bag of ice in about 10 minutes, and actually melted the plastic itself too!
I let off early and coasted to a 9.2 (with a 2.2 60' even), then went home. It runs fine when you're on the road and the ic can stay cool. I guess I need a FMIC before I go back.
