13b vs 13btt fc and fd
Old Jan 14, 2008 | 10:44 PM
Turbome's Avatar
quick question, is the 13b from the fc the same in fds, minus the tts? similar? or can u build it up to the fds motor?
Old Jan 15, 2008 | 07:39 AM
BlueTII's Avatar
Banzai Racing
No, it is not the same
Yes, it is similar
No, it cannot be built up to an FD motor
Old Jan 15, 2008 | 12:21 PM
Turbome's Avatar
well i have this fc motor i want to build up and i'm thinking after its done if i can drop it in a fd roller or have to drop it in the fc.
Old Jan 15, 2008 | 06:29 PM
DarkLikePoe's Avatar
It's dark like Poe.
You can drop virtually any engine you want into an FD, but, while I have no real understanding of the BENEFITS of the 13BT, I'm not entirely sure why you'd swap it in over a 13B-REW. Significant changes were made to the 13B-REW, the twin turbos notwithstanding... and you won't get those with a 13BT.
Consider this:
Cost of clean FD roller = $6000-8000 roughly
Cost of building a 13BT to exceed 13BREW specifications = $3000 or more, depends on parts and labor.
Cost of custom fabrication of motor mounts = $800-1000
Cost of wiring/custom ECU = $1500-2000
So... your project would cost between roughly $11.5K and $14K. You are barely beating the bone stock FD in price and performance for what I promise is more trouble than it's worth.
Do an FC right and drop that engine into it. It'll be a screamer and it won't break the bank.
Old Jan 15, 2008 | 06:43 PM
Turbome's Avatar
thanks for the insight. well look for a built fc motor up for sale later or maybe my fc up here running..or something else.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
