Fuel Tuning.....
Old Apr 17, 2002 | 11:58 PM
Drakk0r's Avatar
Fuel Tuning.....
I recently bought and installed an HKS AFR and started tuning it via an EGT guage. Now, keep in mind I've been tuning with safety in mind, so I've been keeping the EGT's relatively low. My question is this... Right now I have it set to run -25% at idle all the way up to 3500rpms. Where it tapers off... -22%, -20%, -18%... and so on.. running richer and richer as I go to avoid leaning out at high RPMS. While cruising (below 3500 rpms) I stay at about 450-550*C. It gradually gets hotter as the revs go up, peaking at 700-750*C at WOT at the top of each gear. I know normal operating temp on rotories is like 800-900*C or 1650*F. I know that when I didnt have the AFR, I ran so rich it smelled like a lawnmower, and backfired every time I let off the throttle at high RPMS. But was it really running THAT rich? I can set it to -50% at idle and it still smells like unburned gas from my exhaust pipe. I know that its installed and working properly too, cause it made a huge difference in mid range power. Any ideas?
Old Apr 18, 2002 | 01:04 AM
RETed's Avatar
We have no clue unless you tell us what you're running and what kinda mods you've got...
Turbo?
How much boost?
Fuel pump?
Fuel injectors?&nbsp Sounds like you're running 4x720's?
-Ted
Old Apr 18, 2002 | 12:38 PM
2DoritosOnAStick's Avatar
Old Apr 18, 2002 | 12:40 PM
Drakk0r's Avatar
Hah, good point.. I forgot to include my sig.. See below..
Old Apr 18, 2002 | 12:51 PM
Grimlock's Avatar
-50 at idle and still idling...geez! if i put -20 on my safc the engine starts runnin like crap from not enough fuel. maybe you wired it in wrong?
Old Apr 18, 2002 | 01:15 PM
Josepi's Avatar
Despise Enmity
Umm, could your exhaust stink because you have no cats?
Old Apr 18, 2002 | 01:35 PM
RETed's Avatar
I'm a bit confused with your .sig - are you running all of that right now, or all that turbo stuff not installed yet?
If you're still NA, something is drastically wrong, as your -2x% settings would normally prevent the car from running!
-Ted
Old Apr 18, 2002 | 03:38 PM
Drakk0r's Avatar
Yes, I'm still N/A.. The turbo is going on in a few weeks/months... Ok, so somthing is wrong... Any ideas? Cause I know its working to a degree.. I gained quite a bit of midrange power and raised the EGT's through the whole powerband by leaning it out... So what could be causing it? Bad injectors? 02 Sensor? Fuel pump? Any ideas would be helpful..
Old Apr 18, 2002 | 03:49 PM
RETed's Avatar
It sure looks like a stuck fuel pressure regulator!
-Ted
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
