where to buy High pressure AST cap!!!
Old Jan 11, 2008 | 08:39 AM
Doc1023's Avatar
hi all,
last night, i checked my coolant pressure and i notice that AST cap is not holding the pressure. i heard leaking air from AST cap....i need to replace it, but where to buy and what brand?
btw, i have the aftermarket AST...
thanks
Old Jan 11, 2008 | 09:13 AM
Mahjik's Avatar
Mr. Links
Take the cap to Advanced Auto or NAPA. They should be able to match a Stant cap for you.
Old Jan 11, 2008 | 09:30 AM
DaveW's Avatar
Racecar - Formula 2000
Get one w/o the release lever - those have a problem where use of the lever causes the seal to go off center, and not seal properly the next time you use it.
Old Jan 11, 2008 | 11:45 AM
BigWillieStyles's Avatar
dont buy a higher pressure as this will put more pressure on your engine seals, stick with stock pressure.
Old Jan 11, 2008 | 11:58 AM
JKL Racing Engineering's Avatar
most aftermarket AST uses the 1.3 bar cap, so just buy a Stant one from local auto parts store.
Old Jan 11, 2008 | 12:06 PM
DaveW's Avatar
You have two conflicting benefits here:
1. higher pressure = less boiling and better cooling
2. lower pressure - less stress on all cooling system components
IMO, use the higher-pressure caps ONLY if you need to have better resistance to high coolant temperatures.
Dave
Old Jan 11, 2008 | 12:07 PM
Doc1023's Avatar
i will visit NAPA today~....
thanks
Queppa
Nov 18, 2024 03:47 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
