Somewhat odd idle
Old Apr 17, 2002 | 05:39 PM
Rx-7$4$me's Avatar
Somewhat odd idle
I have read around on how to fix this... but Im not sure if I should do it how others suggested it to other problems.
My car has a fine steady idle, but its a little low. I dont have aboost gauge quite yet so I cant be sure I dont have a boost leak, although I did a 40-70 time and got a 4.5 with everything stock except my apexi intake so I believe it is ok.
Right after I changed my plugs my idle was glued at 750, but after a few miles of driving it dropped and is now at a constant 600 or so.When the A/C comes on my car will drop to like 300rpm and then go up to the normal level of about 900rpm while the fans are blasting.
Should I adjust my idle screw? or do I have a possible small vaccume leak?
Thanks.
Stevo
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Rotafuzz
Sep 30, 2015 09:55 AM
