Boost Problem, Help!
Old Jan 8, 2008 | 09:39 AM
spankmywankel's Avatar
Newbie
Hey guys, I just picked up a 94 Rx-7, Auto to Manual swap done by a respected rotary mechanic. Anyway, I've got a couple problems.
A: I'm boost spiking 18PSI off the primary turbo, wastegate seems to be functioning properly but I hit fuel cut if I don't pay attention.
B: I'm boosting 2-4PSI off of the second turbo, releasing the throttle and jabbing it again worked in getting propper boost once but now I don't seem to be getting anything.
I've looked around and I can't find anything on my first issue and on the second I seem to be SOL because I've replaced the Y pipe and intercooler couplers with silicone so no leaks there and all the vacuum lines/pills have been replaced. Lines with silicone hose, so there should be no problem there.
As for a mod list, pretty simple 3 inch stainless steel downpipe, not sure of the brand no visible markings, stock main cat sill in place, Peter Farrel(SP?) 3 inch catback, K&N drop in filter.
Please help guys I'm a n00b to third gens, I had an 87 TII before this, but I couldn't pass up an FD even with a few problems. So help a rotary guy out.
Thanks in advance.
-Ryan
Old Jan 8, 2008 | 09:51 AM
Mahjik's Avatar
Mr. Links
A: Get a boost controller
B: http://www.autosportracetech.com/RX-...leshooting.htm
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
tiger18
Sep 3, 2015 08:27 PM
