Possible to fix this housing?
Old Jan 2, 2008 | 11:37 AM
DelSlow's Avatar
Hot Dicken's Cider
Well I purchased this housing for $230 that was supposed to be in "excellent condition with >8k miles." The seller(Fsunoles06) won't refund my money, so now I'm stuck with it. The wear surface is not in too bad of condition, but the o-ring seats have severe pitting. Is there any way to repair this?
Old Jan 2, 2008 | 11:54 AM
rotoryfreak's Avatar
That looks bad.
If it has piting you will not be able to fix.
Soory.
Old Jan 2, 2008 | 10:39 PM
ultimatejay's Avatar
You can try to fill the pits with epoxy and sanding them down flush, but there is no way to know how long this would last.
Old Jan 2, 2008 | 10:46 PM
t-von's Avatar
Rotor Head Extreme
The seller was shitty for not informing you about this. It looks like the engine sat up over a long period of time without water (typical junk yard engine). If it's not warped and the sealing surface is good, it's very salvageable. You just got to know the little secrets. The water passage pitting shouldn't really hurt much however, I would bead blast it to remove some of the loose material. You wouldn't want any debris clogging up your radiator. The coolant seal lands may need some attention. Any pitting there will cause leakage if it's not completely smooth. Wire wheel the sides of it to remove any pitting you can. Then use some devcon and a razor blade to fill in. Some really hi temp (500 degree) silicon will also work. Remember the housings really don't get that hot as long as the coolant is in them. This keeps the devon and silicon from breaking down from excessive heat.
Old Jan 2, 2008 | 11:04 PM
killahrx7's Avatar
dyno queen potentials
that looks foooked up. sorry
rgordon1979
40
Mar 15, 2022 12:04 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
