Recommended Ride Height for FC
Old Jan 2, 2008 | 02:40 AM
DamianSoul's Avatar
The Choopster
I'm autocrossing my 89 GXL in STS2, and wanted to know if there is a recommended ride height. I have a set of ride height adjustable coilovers with spring rates ~450lb/in front and ~335lb/in rear, and I'm running 17x7.5 wheels with 225/45/17 tires.
Old Jan 2, 2008 | 09:45 AM
wrankin's Avatar
Old Rotary Dog
Do you have camber/caster plates in front and an adjustable camber link in the rear?
-bill
Old Jan 2, 2008 | 12:15 PM
fastrotaries's Avatar
W. TX chirpin Monkey
run it 4" off the ground. SIKE!!!!
Old Jan 2, 2008 | 12:20 PM
SCCAITS's Avatar
SCCAEP
Unless you have scales, take it to a professional shop and have a full setup done. It needs to be corner weighted. If there are no restrictions in your rules, set it as low as possible while still maintaining clearance during suspension travel and without running out of shock. I'll assume you have camber plates/link as that is a must.
Old Jan 2, 2008 | 04:06 PM
DamianSoul's Avatar
The Choopster
Yes, I have adjustable camber plates in the front, and an adjustable sublink in the rear. I also have access to a set of scales. Rules allow lowering the car. I can get my car very low without suspension travel issues, just wanted to make sure that by lowering it this low I wasn't adversely affecting anything.
Old Jan 2, 2008 | 04:10 PM
SCCAITS's Avatar
SCCAEP
ITS cars can't go lower than 5" from the lowest point on the rocker and most take it to this point. I doubt you'll be able to get any lower than that anyways.
Old Jan 2, 2008 | 04:42 PM
wrankin's Avatar
Old Rotary Dog
Probably not with 225/45/17 wheels.
Old Jan 2, 2008 | 08:51 PM
DamianSoul's Avatar
The Choopster
Thanks for the input. I appreciate it.
Old Jan 2, 2008 | 09:08 PM
Valkyrie's Avatar
Run it high enough to clear curbs... that's all you need for autocrossing a street car.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
Ernstudet22
Sep 14, 2015 09:19 PM
