O2 voltage?
Old Apr 16, 2002 | 02:47 PM
dra_gon_lee's Avatar
O2 voltage?
whats the proper voltage getting to the o2? i don't think mines working, and i need to know the voltage going in to know if im getting a signal to it and go from there...
thanks
rocky
Old Apr 16, 2002 | 02:58 PM
HAILERS's Avatar
HAILERS
Voltage goes FROM the 02 sensor TO the ECU. See http://www.howstuffworks.com/question257.htm and bookmark the HOW STUFF WORKS url.
Old Apr 16, 2002 | 06:16 PM
ok, then how do i tell if mine is not working?
thanks
rocky
Old Apr 16, 2002 | 06:37 PM
NZConvertible's Avatar
I'm a boost creep...
Try this:
Oxygen Sensor Diagnosis
Old Apr 16, 2002 | 09:44 PM
HAILERS's Avatar
HAILERS
OR....warm up the engine, disconnect the relief solenoid valve connector (blue on the left side of the engine), pull the connector apart on the 02 sensor, put your meter on it with the setting on dc volts and the lowest reading (looking for less than one volt) and watch the reading while reving the engine. Probably going to read around .8v at idle with the relief solenoid disabled (less than that with the relief valve enabled, like zero or minus some screwy figure). Should vary when reving the engine. EDIT: Oh fudge. No smog pump. Then about .8v at idle. Go for a drive while monitoring the meter. Full throttle b/t .7 and .8volts. Cruising in fifth should be jumping around on either side of approx .4v, wildly and seemingly erratic, but on close observation it'll be jumping back and forth on either side of .4v You can also monitor from pin 2D on the ECU. Middle plug. Counting from the right to the left, the second pin on the bottom on the plug. Thats with the 02 sensor hooked up to all wiring.
Old Apr 17, 2002 | 02:30 AM
man, hailers your the man, when it comes to wiring... thanks!
i got that coil thing figured out, it was the coil! the guy(previous owner) had hooked up the service plug(little black wire hanging by the connector) to a ground so everytime i plugged another in, it would die....
gonna try to hook up my o2 sensor tomorrow...
thanks
rocky
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
WANKfactor
Sep 29, 2015 01:14 PM
rattlehead
Sep 25, 2015 10:55 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
