Progressive idle problem...
Old Apr 16, 2002 | 12:10 PM
Ryde _Or_Die's Avatar
Well when I got my car it idled perfect just about. Then it started fluxuating every so much. Then it would almost die when going around turns with out giving it gas out of gear or having the clutch pushed down. Then it would actually die when turning some. Just now, the car wouldn't idle at all? I am going to look for intake leaks but if I don't find any what could make it get worse and worse? Thanks alot.
Old Apr 16, 2002 | 12:11 PM
any vacuum intake leaks look for.. and check TPS..
how many miles on engine? (just wondering)
Old Apr 16, 2002 | 12:16 PM
What is the best method to look for leaks? Is spraying starter fluid around my engine safe or is there another way? My car has 104k miles on it but the engine was rebuilt about 5 months ago and the car sat the whole time.
Old Apr 16, 2002 | 12:23 PM
CHECK THE PRIMARY INJECTORS, INTAKE LEAKS, ADJUST TPS.
Old Apr 16, 2002 | 02:43 PM
dra_gon_lee's Avatar
if you still have ps, then its prolly the air supply valve, check that out before you change anything...its located on the back of the intake manifold, the side near the firewall, its a large white connector i think?
i diconnected mine, because i have no ps, and my idle dropped like some hookers pants hehe, but in your case it might unplugged and not adjusting the idle for when you ps increased load on the engine....
anyways
heres some links to other stuff to check while that is getting looked at:
http://fc3s-pro.com/TECH/HOWTO/TPS/tps.html
http://www.teamfc3s.org/info/articles/idle.html
http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
Old Apr 16, 2002 | 04:13 PM
Thanks alot guys, ima have to make time to check everything out.
squirrels
Sep 1, 2024 09:52 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
