S4 TurboII Master Cylinder upgrade
Old Dec 24, 2007 | 09:36 AM
SpecFC's Avatar
SOUL-LESS
Hey all,
Ive recently begun replacement of the brakes in my 87 TII.
In the effort to improve braking, ive spent some time trying to figure out a M/C upgrade.
Fortunately, I work in a parts store, so I have access to view any M/C I choose.
What I have found is:
The M/C from a 1993 626 V6 without ABS, and with a manual transmission appears to be identical to a S4 TII master cylinder, aside from having 3 outlets, and a 15/16'' bore as opposed to the 7/8'' bore of the stock TII cylinder.
I have yet to test fit it onto my car yet, but it appears as though there is hope for a direct bolt in upgrade for the M/C.
Ill let everyone know how it works out.
Old Dec 24, 2007 | 04:35 PM
owen is fat's Avatar
upgrade?
for what downfall?
Old Dec 26, 2007 | 06:07 PM
SpecFC's Avatar
SOUL-LESS
An upgrade doesn't necessarily mean there was a downfall. However, there comes a time when stock TII brakes are not enough.
Old Dec 26, 2007 | 06:47 PM
Turbo II's Avatar
It's only Rock and Roll
Try tires yet? Never had a problem with my stock system.
Old Dec 26, 2007 | 07:53 PM
RETed's Avatar
Nice!
Keep us updated!
Converting over to a 929 set-up is a pain in the ***!
Might want to check out some of the larger / heavier Mazdas like the MPV vans and the Millenia...
-Ted
Old Dec 26, 2007 | 09:10 PM
Turbo II's Avatar
OK, after maybe putting my foot in my mouth now I'm curious about this. I looked at the other similar threads listed below and also your on your site again Ted about brakes, and I'm going to go searching in a few for more on here also but... all I've ever seen are a lot of posts in the past saying "tires" (besides everything else about rotors/pads/lines/etc) being one of the more important factors but have never run across any before about upgrading the MC.
Old Dec 27, 2007 | 10:25 AM
RETed's Avatar
Sorry, I'm looking at it from a BBK perspective.
I'm interested cause of aftermarket brake calipers, which don't always come in "nice" piston sizes.
Being able to manipulate the brake master cylinder bore size is a plus.
I currently run Wilwood Dynalites with larger-than-stock brake piston sizes, so it's a little bit soft.
I can compensate a little with more aggressive brake pads, but you can only do so much.
Being able to change the brake master cylinder bore gives me more options...
-Ted
Old Dec 27, 2007 | 10:09 PM
SpecFC's Avatar
SOUL-LESS
My real goal in all this isn't really about better braking, but better brake feel.
I highly doubt a bigger M/C will aid in braking other than providing more resistance to fade induced lack of brake pedal (more fluid movement=more compression of air bubbles). All I hope for is a stiffer pedal at light pedal pressures, its more of a stop and go gentle kind of driving thing im after than max preformance.
Old Dec 31, 2007 | 09:00 AM
I know you are looking at a larger master BUT a smaller master would require more travel thus more feel... just like a longer lever arm provides more precision, but hey do whatever you want.
Old Jan 1, 2008 | 01:00 AM
uptotibet's Avatar
so did it fit?
Old Jan 1, 2008 | 02:56 PM
SpecFC's Avatar
SOUL-LESS
Haven't had a chance to yet, been very busy with work, and holidays. Ill do it this week and post up my findings.
Old Jan 2, 2008 | 11:50 PM
socalrotor's Avatar
so...........anything yet?
Old Jan 5, 2008 | 09:39 PM
SpecFC's Avatar
SOUL-LESS
Yep, Finished last night. The master cylinder itself is identical to a non abs RX7 M/C.
Other than, the reservoir. The inlets for the 626 M/C are slightly too far apart for the RX7 M/C to mate right up. However, because the 626 has an remote mount reservoir, the new M/C also came with new fittings and tubes for the reservoir. SO, all that has to be done is to mount the rx7 reservoir somewhere convenient and above the M/C, then drill and tap two holes in the bottom where the nipples would be, and thread in the adapters. I will not be driving the car for a few months so I cannot report the benefits of the M/C, but I can say that it fits, with some minor modification.
Old Jan 6, 2008 | 01:57 AM
Black91n/a's Avatar
Some people like a lighter effort and more travel to modulate, others like a shorter stroke and more force to modulate.
One thing that vastly improves feel is a brake master cylinder brace. I just wrote up a how to on making one for an FC. Highly reccomended modification.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/how-diy-brake-master-cylinder-brace-718744/
Old Jan 6, 2008 | 11:41 PM
SpecFC's Avatar
SOUL-LESS
I'm definately going to be doing that as well!
Frisky Arab
Sep 4, 2015 06:17 PM
