Rota Wheels. Do they make good wheels for drifting?
Old Dec 23, 2007 | 06:36 PM
K!NCH's Avatar
Specifically Rota Slipstreams. I'm looking into 17 x 8 with a +35mm offset. Any opinions?
Old Dec 23, 2007 | 08:02 PM
Mahjik's Avatar
Mr. Links
Probably one of the better disposable wheels out there.
Old Dec 23, 2007 | 11:59 PM
K!NCH's Avatar
Yeah I sorta figured cause they're just imitations of famous wheels. But do you think they'd hold up for a while. If not, are there any five spoke designs youd suggest for drifting. Preferably in a 17"
Old Dec 24, 2007 | 03:35 AM
aznpoopy's Avatar
strike up the paean
#1 it's not that serious. unless the wheels are made out of tin foil you aren't going to break them just by drifting unless you hit something. and if you hit something dead on going fast, it doesn't matter if its volk or rota. it'll be done.
#2 if you are just starting out, stock wheels with cheap tires are fine, and they keep the costs down. smaller skinner tires / wheels will also be easier to break loose so you can get the basics down at lower speeds, ensuring that you don't break something very badly and/or kill yourself.
Old Dec 24, 2007 | 03:50 AM
Tai-Lun's Avatar
Re-build... again...
Cheaper and definitely one of the more disposable wheels out there, but offsets are not that aggressive.
Old Dec 24, 2007 | 09:23 AM
Mahjik's Avatar
Mr. Links
The Subbie guys use this wheel for rally driving, so I'm sure they'll hold just fine for some drifting (until you smack a barrier or two). I'm thinking of buying a few sets next year to mount track tires to.. I like the idea if something happens I can cheaply replace one.
cristoDathird
28
May 30, 2019 08:47 PM
