egt temp might not be good enough????
Old Apr 16, 2002 | 10:12 AM
T210thAnniv's Avatar
Question egt temp might not be good enough????
I got a exhuats temp, waiting for RB downpipe to install. Its a autometer phantom gauge that reads to 1,600 degress max. My friend tells me that the t2's might run hotter then that, around 1,650 normal, and the gauge will be useless. Does anyone know for sure how hot the t2's run??
Old Apr 16, 2002 | 10:40 AM
MikeL's Avatar
I was told by RP that about 825°C is the most I should have, for safety. I have never seen 825° but, I've been close.
825°C = 1517°F
Old Apr 16, 2002 | 10:54 AM
Grimlock's Avatar
looks like you just made it with that gauge! i have an egt gauge and the probe is on the down pipe right next to the oxygen sensor. i never see any higher than 800C which is somethin around 1600F.
at idle i get just under 400c (just under 800f)
cruising 600c (just under 1200f)
wot 700c-800c ( just under 1400f-1600f)
i know my numbers arent exact. i forget the formula so i just double up on the celcius reading which is pretty close.
Old Apr 16, 2002 | 12:56 PM
RETed's Avatar
If you have it in the downpipe, it reads about 100&#176F lower than in the turbo exhaust manifold.&nbsp If you stay safe, 1600&#176F is okay - once you lean out, the gauge will peg!
-Ted
immanuel__7
89
Sep 5, 2015 10:23 AM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Wolf_
Aug 11, 2015 04:23 PM
