rich w/ advanced timing vs. lean w/ retarded timing
Old Dec 19, 2007 | 04:17 PM
arghx's Avatar
rotorhead
The author of these two articles essentially argues that, given enough octane it seems, you are both safer and making more power by retarding timing presumably during peak load/combustion pressure. The safety of the retarded timing should allow you to run a leaner mixture, which in turn yields more power. Running richer is safer not so much because it cools combustion, but because it slows the flame-front.
These two articles written by one of the main guys at Innovate Motorsports, which of course sells all sorts of tuning products including widebands:
Some quotes:
http://www.innovatemotorsports.com/resources/rich.php
Because air has a specific heat of about 1 kJ/kg*deg K, the air charge is only 3.8 C (or K) degrees cooler for the rich mixture compared to the optimum power mixture. This small difference has very little effect on knock or power output.
Richening up the mixture results in a slower burn, moving the pressure peak later where there is more leverage, hence more torque. Also the pressure peak is lower at a later crank angle and the knock probability is reduced. The same effect can be achieved with an optimum power mixture and more ignition retard.
http://www.innovatemotorsports.com/resources/myths.php
If the mixture is ignited to early, the piston is still moving up towards TDC as the pressure from the burning mixture builds. This has several effects:
The pressure buildup before TDC tries to turn the engine backward, costing power.
The point where the pressure in the cylinder peaks is much closer to TDC, with the result of less mechanical leverage on the crankshaft (less power) and also causes MUCH higher pressure peaks and temperatures, leading to knock.
Many people with aftermarket turbos don't change the spark advance very much, believing that earlier spark creates more power. To combat knock they make the mixture richer. All that happens really then is that the mixture burns slower and therefore hits the peak pressure closer to the right point. This of course reaffirms the belief that the richer mixture creates more power. In reality the flame front speed was adjusted to get the right peak pressure point. The same result (with more power, less emissions and less fuel consumption) could be achieved by leaving the mixture at the leaner optimum and retarding the ignition more instead.
anyone have thoughts on this? Also I'm still trying to figure out how octane fits into all this idea... and obviously he's not talking about a rotary but similar principles should apply right? I am going to be tuning a race gas setup myself (still working on driveability before I boost it) so I'd like some input.
Old Dec 20, 2007 | 11:19 AM
cewrx7r1's Avatar
Eye In The Sky
This has been posted before and applies to piston engines which run cooler exhaust temperatures.
Old Dec 20, 2007 | 12:12 PM
TEZTnTUNE's Avatar
BUILD, TUNE, RACE, REPEAT
argh the author of the article is correct. cewrx7r1 is also correct. in theory and under certain condition(think "optimum") he would be absolutely correct. but those of us know the real world isnt optimal whats so ever. we deal with bad gas, super hot days, high under hood temps, high exhuast temps, u name it.
given a good knock control strategy i would agree with him.
Old Dec 20, 2007 | 12:17 PM
TEZTnTUNE's Avatar
also the size of the saftey margin u want to have is something to be considered as well. we rotary guys arent given the margin the piston boys have. hell some oem are experimenting with acceptable knock conditions in order to meet the emissiions demands set on them in the near future
Old Dec 20, 2007 | 02:52 PM
arghx's Avatar
rotorhead
what about for a race gas tune? I will be running 110.
Old Dec 21, 2007 | 11:57 AM
ChrisRX8PR's Avatar
Interested in reading more about this, anybody else?
Old Dec 21, 2007 | 02:38 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
interesting
Old Dec 22, 2007 | 05:19 AM
crispeed's Avatar
'Tuna'
That's one advantage of higher octane. It allows the envelope to be pushed. It's a smaller margin when applied to a rotary engine and one which many tuners don't believe the positves out weigh the negatives but yes higher octane will provide the benefits to use more ignition timing, leaner afr's and more improt higher boost levels. It's up to the tuner to know those limits though because every combination is different.
Jun 26, 2016 10:21 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
Microtech
Aug 23, 2015 11:04 AM
20B Forum
Aug 19, 2015 01:47 PM
