squeaky noise in the back of my Fc
Old Apr 15, 2002 | 05:11 PM
Question squeaky noise in the back of my Fc
Is this the old suspension, i hear it over bumps and shifting? shocks, struts, springs?
Old Apr 15, 2002 | 05:14 PM
cymfc3s's Avatar
I Raise Chickens
or the hatch. Drive it around with a buddy and have to him listen around for where its coming from.
Old Apr 15, 2002 | 07:45 PM
pretty darn sure it's not the hatch, makes a creeking squeaking noise
Old Apr 15, 2002 | 07:47 PM
Icemark's Avatar
swaybar has dirt between it and the rubber in the clamps.
Old Apr 15, 2002 | 08:37 PM
rx-7fc's Avatar
mine is squeaky when you are stoping but when you are
going slow coming to a stop and it from the back and the other squeak is when you go over speed bumps but that might be the struts or springs do you what that might be
Old Apr 15, 2002 | 10:50 PM
Squeeky noise!
I have had that same problem for a long time - I noticed that the noise was not present when the car was cold and then later when it warmed up the squeeking started. I lubed everything underneath the car, and changed the rear struts with no success. In changing the rear struts I noticed that the upper spring bushing was dried out and worn - I am going to lube this bushing - I'm hoping that it is what is making the noise - try it and let me know if this helps you!
Old Aug 2, 2002 | 09:52 AM
I have the same problem on my 91 convertable, quiet when cold, squeeky when hot.... I'm going to try putting it up on jacks tonight and see if something is rubbing. (maybe expanded metal when hot?)
Old Aug 2, 2002 | 09:54 AM
rico05's Avatar
WTB S5 N/A FC
Mine had the same symptoms, and I put on new exhaust "donut" rubber hangers on the mufflers. Fixed it right up.
Old Aug 2, 2002 | 10:31 AM
Rob500's Avatar
Same with me.
Rob
Old Aug 2, 2002 | 11:09 AM
Wankel7's Avatar
Haven't we ALL heard this
It could be the short small stuby sublink. I believe that may be the problem.
James
Old Aug 2, 2002 | 09:48 PM
DCmina's Avatar
where can you get some of those "rubber donuts"?
Old Aug 2, 2002 | 10:56 PM
TRURX7's Avatar
Do you mean the bushings? I assume you mean to take it apart and clean then re-grease it?
Old Aug 2, 2002 | 10:58 PM
liquidferrum's Avatar
ok...this will sound really stupid but what does fc mean?
TRURX7's Avatar
I also have a similar squeak that I hear primarily when I shut the car off and the engine is still wiggling for that last millisecond. I think it may be like a rusty motor mount or something. My car is nearing the 170k mark and probably a lot of the bushings/mounts are giving out.
Old Aug 2, 2002 | 11:18 PM
chaos7's Avatar
FC is second gen for short.
Old Aug 3, 2002 | 01:14 AM
how do you get second gen out of FC?
Old Aug 3, 2002 | 01:23 AM
BlackRx7's Avatar
Daily Domestic Killer
FCS3 is the first 4 character of the 2nd gen vin #
Old Apr 16, 2004 | 01:05 AM
aka_rocket's Avatar
7s bein a pain in the ass
i have been having the same problem with the rear squeaking but it occurs when my car is cold. later when i've driven the car for a while, it no longer squeaks. and this squeak occurs at low speeds, like when you slowing down and crawling over a speed bump.
msilvia
28
Apr 14, 2016 12:58 PM
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
R7rexy
19
Sep 2, 2015 10:24 AM
20B Forum
Aug 30, 2015 12:08 AM
