rx2 help!!
Old Dec 8, 2007 | 11:54 AM
BLACKrotor92's Avatar
rx2 help!!
dose the hole suspention from a 84-85 gsl se 1st gen rx7 fit on a 73 rx2??
Old Dec 8, 2007 | 03:00 PM
Jaime Enriquez's Avatar
OLDROTA
Not a bolt in.
Old Dec 8, 2007 | 03:38 PM
i need to know wut that means because im buying the car for the suspention this week can i use it or not wut do i need for it if i can
Old Dec 8, 2007 | 08:46 PM
Jesuscookies's Avatar
I can haz rotary?
I am pretty sure you will need:
Camber/Caster plates to correctly adjust the suspension.
Change top to a 4 bolt design.
Shocks are shorter. You will need to put something inside the tube to lift it to the correct height.
I am not sure if you will have to fiddle with anything to get the tie rods to work, but everything is about an inch longer than on an RX2, which means you will need to do something for fender clearance.
Old Dec 8, 2007 | 09:15 PM
RotorRican's Avatar
Rotary Loco
Talking
Hello
also, if I might add,
the brakes lines have a different thread pitch.
Old Dec 8, 2007 | 09:22 PM
soo is the gsl se better then the rx2 suspention?
Old Dec 8, 2007 | 11:25 PM
d0 Luck's Avatar
raysspl.com
yes
Old Dec 10, 2007 | 12:39 PM
Siraniko's Avatar
RX for fun
Do it right and get a camber kit as the strut tops bolt pattern is different from a first gen (3 vs 4bolts) or modify the strut insert to fit the RX-2 strut top.
Drilling holes to fit a 1st gen strut/top is not in my book and I consider that as mickey mouse job. But again, that is just me where functionality and appearance comes hand on hand.
chiefmg
Sep 10, 2015 07:46 AM
