Sponsored by: CARiD
Weights of Counterweights
Old Dec 7, 2007 | 06:56 AM
RETed's Avatar
When I weighed Zenki FC (turbo) versus Kouki FC (turbo) rear counterweights, they were within 0.2 lbs. of each other.
It's pretty much negligible, since my scale resolution was 0.2 lbs. :P
This was on a certified weight scale - 100 lbs. max, 0.2 lbs. min resolution.
It's the kind of scale you see at the supermarket / meat cutter / deli / etc.
As a general rule (at least for FC rear counterweights), the number of holes drilled is a pretty good indicator of what years it came from.
One hole is usually Zenki FC.
Two or more is usually Kouki FC.
If it had 3 or more holes, it's almost guarans Kouki FC.
If you're going to dynamic balance everything, does it really matter?
Side note, Kouki FC / FD / Cosmo 13B are all interchangable, since all those rotors weigh the same.
-Ted
Old Feb 21, 2008 | 08:38 PM
-Ted
Does that mean a S5 flywheel can be used with S4 rotors & front counterweight? Being that the difference between s4 & 5 rear weights was withon 0.2lb?
Or am I missing some fundamental difference like position of weght on the flywheel?
Refering to stock flywheels btw.
Old Feb 22, 2008 | 04:50 AM
RETed's Avatar
No, counterweights need to be matched with the rotors.
S4 rotors -> S4 counterweights / flywheel
S5 rotors -> S5 counterweights / flywheel
The counterweights are drilled on the edges for a reason.
Without getting into a real long discussion which would include college level physics on momentum / derivation and integration of mass / lever moment / centripetal force...
Mass and weight affect a spinning object at the edges rather than the center.
Even though the total weight of the counterweights are almost identical, it's the small holes on the edges that affect the rotational mass more.
Don't try and swap the wrong counterweight / flywheel.
The engine will eat it's bearings in a jiffy!
-Ted
Old Feb 22, 2008 | 06:47 AM
Ha yeah ok then, something like what I was thinking.
I certainly don't want to get into "college level physics on momentum / derivation and integration of mass / lever moment / centripetal force..."
So I'll stick with the "more about the position of the weight" concept.
Thanks Ted.
MILOS7
May 9, 2016 06:39 AM
