My new project car '82 Mariah Mode One
Here's the juicy details.
1982 GS stock 12A 98,040 miles
Mariah Mode One wide body kit
600cfm Edelbrock performer series carb (not tuned yet)
Racing Beat intake manifold
Monza? header
no emissions, no AC, manual steering, manual windows
It's pretty trashed... But it runs and I got it for 600 bucks! The interior is all trashed so I already started stripping it. Suspension is completely trashed, feels like all the struts are blown. The OMP is squirting out onto the ground. Clutch master cylinder is leaking out the back and underneath the carpet. Windshield is busted.
I would like to find the person who let the car get to this condition and kick their ***.
I installed new leading plugs and put some fresh gas in to dilute the old 40:1 premix jetski gas that I put in it (yes I did), and she started right up. Drove her around the block and now the speedometer mysteriously doesn't work. I go to turn the headlights off and the dash lights go dim and then blow a fuse... replace the fuse and hear a pop, one headlight goes up, no running lights. Turns out the wiring harness for the left front running light is tangled and wrapped several times around the headlight arm, and had popped the arm off the pivot and cut through the wiring harness. HAHAHA!!! bitch.
On a positive note, I have located some TII seats to replace the trashed seats in the car.
Monza? header
Trending Topics
Maybe I'm just retarded but the OMP flange is not the exact same shape as the block off plate that Mazdatrix sent me. Is that normal? I double checked the part numbers.
Does anyone know if I can get the clutch hydraulic hard line from Mazda?
Actually the original color is brilliant black from the paint code on the firewall. Someone painted it red and then black again. It will get another fresh coat of black when it's ready.
600 was a steal with the kit and wheels alone, even if it didn't have a drivetrain. The wheels look similiar to the Almex ones the kgray has, but they aren't the same. What size are they, including tire size?
Well that is the Mariah Flying Whaletail. It's the proper wing for the Mariah wide body, and supposedly pretty rare. Not to mention they cost like 400+ bucks when new. So based on those reasons it might stay on. I was pretty shocked by it at first also, but it's starting to grow on me.
That wing, which is the same one I have on my widebody, is period correct for both the kit and the era. They sold for $436 new and are NLA. They are already getting hard to find.Impulsive, if the lug holes have been widened, chances are they were the 4X108 Ford bolt pattern. If that's the case, I hope you're using shank nuts since the rims are most likely bolt centric and not hub centric.
