Far East Forum Serving Asia and surrounding Areas. Far East users, post event and club info here
Part number for 99'spec-up engine block
Old Dec 5, 2007 | 06:59 AM
mazdafun's Avatar
Hi all.
Is there anyone who knows if there is a difference, and what it is, on the engine block of the FD3S 99-up model year vs. the "old" pre-99 Model year block?
I am thinking about buying a new replacement block for my 1993 Euro Spec FD from Mazda, but if there is any significant changes on the 99-spec block making it better, I will order it instead. It also has to be interchangeable with the aux I have with little or no mods. (It is all stock btw, Twins, etc)
The partnumber for the Euro spec Fd is : N3A1-02-200 originally with a direct transfer to N3G1-02-200.
Can anyone verify the partnumber for the 99-up engine block?
Thank you in advance.
Note : Before you get on your flame-horn, I ask here bechause it is impossible to get Japan partnumbers anywere but Japan, and the 99 FD was only sold in Japan.
Old Dec 7, 2007 | 12:44 AM
mazdafun's Avatar
Found it !
Hi all.
I found it trough other channels, but I'll post it here if anyone else is curious and do a search.
Partnumbers are:
N3G1-02-200 is manual transmission Spirit R
N3G3-02-200 is auto transmission Spirit R
Old Dec 10, 2007 | 03:11 AM
billyboy's Avatar
Might be a bit late, fwiw, only appreciable change between early and late long blocks is the metering oil pump, so wouldn't get too wet about it.
Those part nos apply from 12/98 production as well.
Old Dec 10, 2007 | 09:01 AM
mazdafun's Avatar
Hi.
I didn't get that "wet" over it =)
The numbers match what you get here in Europe as well for your 93 FD since the number change.
I just wanted it verified. How much is a new block over the counter in Japan, and do you actually get a new engine, or is it reman?
Thanks for the replies. Keep them comming =)
Ciao
Old Dec 10, 2007 | 02:44 PM
billyboy's Avatar
New not reman - before sales tax I believe.
and that was a typo above, should be short, so not even sure you end up with the new and improved(?) MOP.
You can source the engine cheaper outside Japan bizarrely.
Old Dec 14, 2007 | 05:57 AM
mazdafun's Avatar
Thanks
Wow !
Thanks for the info. Were do you consider the best/cheapest place is to get a new block from (not remanufactured) ?
Have a nice day
Old Dec 14, 2007 | 05:17 PM
billyboy's Avatar
I believe the cheap(er) engines we get are sourced from a couple of islands off the east coast of Australia, which the local friendly dealership here charges $Aud9K+ for. I'd expect those cheap engines are close to $3k if you could find the original source...before various profit margins,shipping and tax are added in.
This might be an easier solution for you.
https://www.rhdjapan.com/jdm-low/Maz...D3S-RX-7-30884
josef 91 vert
23
Sep 3, 2015 11:20 AM
BLK 93
Aug 19, 2015 03:47 AM
04G35S
Aug 14, 2015 07:31 AM
