Losing power, bucking and stalling uphill
Old Nov 29, 2007 | 07:54 PM
lfd75's Avatar
Hi everybody,
As stated in the title my 83 GSL has the following problem. When I'm driving up a steep hill the car starts to buck and lose power eventually stalling (even flooring the accelerator won't help once it's started). The car will always start immediatly and run well until I hit the next steep hill and the problem will happen again. This happens about 85% of the time and I've noticed it happens in 2nd gear at about 3000rpm (I don't know if this matters but it's what I've observed). I'm running a can of seafoam in the gas tank and I've cleaned the ***** out of the carb but it hasn't helped. I'm thinking the fuel filter might be clogged so I'll start there hopefully this weekend.
Do you guys have any other sugestions?
Cheers,
Luis
Old Nov 29, 2007 | 07:59 PM
Jeff20B's Avatar
Lapping = Fapping
Fuel filter.
Old Nov 29, 2007 | 08:07 PM
Dan_s_young's Avatar
Turbo widebody FB
Fuel filter and other tune up items are a good place to start. I would also consider doing a fuel pump volume test after replacing the filter.
Old Nov 29, 2007 | 10:38 PM
trochoid's Avatar
Old Fart Young at Heart
As the others have stated fuel filter first. Take the old filter and cut it apart. If you find small rust particles, drain and flush the fuel tank.
Old Nov 29, 2007 | 11:19 PM
Slammed_GSL's Avatar
Check your CAT, bet it's collapsed and is choking the motor when it's pulling hard.
You gotta exhale after you inhale.....
Happened to me.
Old Nov 29, 2007 | 11:32 PM
KCGSLSE's Avatar
Fuuuuuuck Still Here
My friends gsl would do the exact same thing. He had a giant hole in his gas tank and it was starved for gas on hills. Your gas tank could be rusting out and its clogged your fuel filter.
Old Nov 29, 2007 | 11:45 PM
trochoid's Avatar
Happened to me.
A clogged cat will cause power issues all the time, not just going uphill as his problem does.
Old Nov 30, 2007 | 12:02 AM
Cool
My cat caused me to have issues when pulling hard, it started and ran fine untill you floored it or tried to press the motor in to working hard....so yes you are correct, but I still think it's the CAT.
Old Nov 30, 2007 | 12:24 AM
wanklenoob's Avatar
Ambulance-7 driver
MAKE SURE YOU DOWNSHIFT!!! lol but really check your fuel filter.
Old Dec 3, 2007 | 08:22 PM
So what was the fix for your problem?
Old Dec 4, 2007 | 06:17 PM
lfd75's Avatar
Thanks for the replies everybody,
I've been busy with school this last week so I haven't had a chance to change the fuel filter yet but I'll get on that this week and see what happens.
Cheers,
Luis
P.S. Slammed_GSL, I don't have enough posts to reply to your pm yet.
Old Dec 10, 2007 | 06:18 PM
lfd75's Avatar
I just wanted to thank everybody who contributed to troubleshooting this problem. It was the fuel filter after all, the gas coming out of it was full of black sediment and there was a piece of rubber inside it no rust though (thankfully). I took it for a nice ride up a couple of hills and it runs really smooth.
Cheers,
Luis
Old Dec 10, 2007 | 07:42 PM
Jeff20B's Avatar
Lapping = Fapping
Yay!
Old Dec 11, 2007 | 12:26 AM
lfd75's Avatar
I'm not sure if yay is the right word (now I'm on to do some electrical troubleshooting)
Old Dec 11, 2007 | 12:33 AM
Jeff20B's Avatar
Lapping = Fapping
It sounded like the right one-liner to use after my first post in this thread. Short and sweet as in Yay it was the right solution to your question! No need to type a bunch to help this guy.
Old Dec 11, 2007 | 11:21 AM
lfd75's Avatar
I got the one liner , I just meant I shouldn't cheer because now that the easy fix is done I get to move on to the much more tedious task of tracing a short.
distr0
Megasquirt Forum
48
Mar 18, 2022 06:17 PM
Rotospectre
Mar 28, 2018 03:33 PM
gtcd
30
Aug 19, 2015 02:44 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
