VIN decoding
Old Nov 27, 2007 | 07:40 PM
Impulse2k1's Avatar
VIN decoding
I am going to go look at an 85 rx7, but I don't know if it is a base model, gs, or a gsl. All I know that it is a 5 spd car and a 12A motor. I was trying to decode the VIN using the 2nd gen decoding thing that I found. I also would like to avoid using carfax if I can just figure out how to decode it.
Thanks
Old Nov 27, 2007 | 07:55 PM
85 FB's Avatar
7-less
Don't worry about the decoding bit. The trim level should be on the back of the car, unless someone decided to remove it or it broke off.
Old Nov 27, 2007 | 07:56 PM
Rx-7Doctor's Avatar
You know, I don't remember a chart that told you the model by vin #. The only identifier that gives info in the vin is for the engine which would be the 8th character.
1 for 12a and 2 for the 13b.
Maybe someone else has more detailed info besides what we already have in the FAQ section about how the differences between the models which might be your best bet.
Old Nov 27, 2007 | 08:03 PM
waysrx7's Avatar
Apathy Isn't Laziness
http://www.xs4all.nl/~erix7/rx7vin.html
GSL will have rear disk brakes GS has drums.
Old Nov 27, 2007 | 08:23 PM
Impulse2k1's Avatar
Is that pretty much it? I can tell from the picture that there isn't any markings/badges on the back
Here is the vin if it helps anyone
JM1FB3312F0856211
Old Nov 27, 2007 | 08:27 PM
Rx-7Doctor's Avatar
Like I stated the Vin tells you nothing. Go to the FAQ section and click on the thread that explains the differences between the models.
Old Nov 27, 2007 | 08:28 PM
Impulse2k1's Avatar
This site should become a sticky
Old Dec 15, 2007 | 08:53 PM
KetteringRotorhead's Avatar
Suffering Rotary Relapse
go to http://blackdragonauto.com/icatalog/rx/t.asp, look at the rx7 catalogue. In the first few pages, it shows you how to decode VIN's
Old Dec 15, 2007 | 09:08 PM
Vashner's Avatar
Look in the non technical sub forum.
foxbod88
Sep 23, 2015 09:07 AM
Junkee
Aug 15, 2015 01:57 PM
