would this fit?
Old Nov 27, 2007 | 01:22 AM
LBC_FC3S's Avatar
Compita Racing
would this fit?
i wanted to see if 18x9 20 offset would fit the front. i know a wide fender would have to be in use but would i have to use any spacers? would it look funny with that size all around?
Old Nov 27, 2007 | 01:34 AM
JYM's Avatar
JYM
Always in style
I believe you would only need spacers if your offset was higher (thus making your wheels closer inward to your shocks/struts). A lower offset (when positive, at least) means the wheel will come out farther. I know for sure that 18x9 with 20mm offset won't fit the stock front fender. I'm not too much help...
Old Nov 27, 2007 | 01:38 AM
Jaiyurai's Avatar
Endure Persevere Succeed
I'm guessing you mean on an FC by looking at your screen name.
An 18x9 +20 will not fit stock fenders WITHOUT front coilovers, fender rolling/pulling, or front widebody fenders.
Old Nov 27, 2007 | 01:47 AM
LBC_FC3S's Avatar
Compita Racing
was thinking about 30mm fender but dont want it to be too close. maybe 50mm? i dont have the 18x9 20offset for the front. the front is what i have now. 18x8 40offset. the rears, 18x9 20offset havent come in yet. the place that sold them to me gave me 225x40x18 but i think thats too small for the rears. i can use them for now but i will for sure look for something in the 255 area and up for the rears.
Old Nov 27, 2007 | 02:06 AM
LBC_FC3S's Avatar
Compita Racing
these are the rims.
Attached Thumbnails would this fit?-mazda-rx7-turbo-2-039.jpg   would this fit?-18x8-40.jpg   would this fit?-18x9-20.jpg
Old Nov 27, 2007 | 04:04 AM
Ltdnismoracer4's Avatar
axis widetracks
Old Nov 27, 2007 | 10:28 AM
LBC_FC3S's Avatar
Compita Racing
yup. anyone with them?
Old Nov 27, 2007 | 12:01 PM
unicorn_squad's Avatar
they will fit. they' should even clear the stock fenders if you just roll up the lip and run a 235 or smaller tire....
also depends how much camber, but I fit 17x9 +17 with 235/40 under stock barely rolled fenders and ~ 1.7 degrees of camber.
Old Nov 27, 2007 | 08:48 PM
Josh18_2k's Avatar
with coilovers you can fit 255's up front in that offset (and wide fenders). i'd be a little concerned about tire height tho. i dont know available 18" tire sizes, but i do know that 255/40/18 is way too tall. is there a 30 or 35?
30mm fenders are plenty wide enough to cover it.
Old Nov 27, 2007 | 11:49 PM
specialop's Avatar
stitch
Kudos on the some nice wheels. Being that the stock tire is a 205/55/16, the equivalent as an 18 would be a 205/45, 215/40, 225/35,etc... I think the 225/40 would fit quite nicely as it would stretch a bit.
Old Dec 18, 2007 | 11:59 PM
LBC_FC3S's Avatar
Compita Racing
Talking
just got rears in.
Old Dec 19, 2007 | 01:05 AM
Josh18_2k's Avatar
ooh those ***** is pretty.
get em on already!
Old Dec 19, 2007 | 10:39 AM
LBC_FC3S's Avatar
Compita Racing
im getting a motor put in the car first then ill put them on.
Old Dec 26, 2007 | 10:11 PM
battleaxe's Avatar
Rock Slaggin' Jam Rocker
the answer will always be
yes
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
