Volumetric Efficiency
Old Nov 26, 2007 | 11:29 AM
fde2blk's Avatar
A few words from a frustrated student of engineering... Does ANYONE out there have real numbers from testing the N/A 12A's through 85? How about the 13B? It's obvious why this info is hard to find, because if I was designing and selling a motor to a mass of consumers, I wouldn't want to admit that my engine only hit it's peak chamber filling efficiency at 6000 rpm, or whatever it may be... but I'm tired of not knowing.
I have an '84 gsl that I built a blow through system on a budget for, and I guess I'm looking to see how badly sized the cheap turbo that I nabbed for it is. If you have any real numbers, or a link to a sheet of values that you have from testing your own setup, please post! Also, if you could include what intake you were running and what carb/throttle body, it would be so helpful!
Old Nov 26, 2007 | 03:39 PM
locopr1's Avatar
Great question. Well beyond me to answer, but Id like to know also...
Old Nov 26, 2007 | 04:05 PM
orion84gsl's Avatar
My 7 is my girlfriend.
I'm not sure if this is what your looking for, but Sterling sent this to me as a little lesson in VE
12a rotary max RPM = 9000
12a rotary cid = 70
That's 70 cubic inches each rotation, times 9000 RPM, = 630,000 cubic inches per minute.
12 inches x 12 inches x 12 inches = 1728 cubic inches per cubic foot.
630,000 cubic inches divide by 1728 cubic inches per cubic foot = 364.58 cubic feet per minute.
That means that theoretically, a 365.58 cfm carb would be maxed out on a 12a rotary running at 100% Volumetric Efficiency @ 9000 RPMs.
Now I say "theoretical" because the carburetor would have to be absolutely perfect - a "theoretical" perfect, at that. And no carb is perfect.
Old Nov 26, 2007 | 04:19 PM
vipernicus42's Avatar
Rotoholic Moderookie
No hard numbers, but some awesome theorizing in this thread:
https://www.rx7club.com/showthread.p...ric+efficiency
Jon
Old Nov 26, 2007 | 04:35 PM
n2318r's Avatar
fde2blk, check your PM. I think the people who can best answer your question don't lurk in this particular section. On this forum, search in the General Rotary Tech Support section as it has been discussed there. Type in volumetric efficiency and select general rotary tech support section, and you will get a number of results.
Or search/ask in the rotary engine building and porting section of the "other" forum.
Old Nov 29, 2007 | 10:51 AM
fde2blk's Avatar
thanks for the info, n2318r!
C. Ludwig
Jan 30, 2019 06:31 AM
BLUE TII
Sep 26, 2015 10:12 PM
RedBaronII
Sep 20, 2015 11:29 AM
j_tso
1st Gen General Discussion
Sep 11, 2015 09:33 PM
