Waste gate and boost controller?
Old Nov 26, 2007 | 11:23 AM
silverflash2's Avatar
If using a electronic boost controller hooked up to the waste gate, does it matter what spring is in it. Do you have to take the spring out?
Old Nov 26, 2007 | 06:19 PM
skir2222's Avatar
I win
You leave the wastegate alone, hook up the lines to the solenoid and your set. A boost controller is only made to increase boost, and help prevent boost spikes.
Old Nov 27, 2007 | 12:07 AM
arghx's Avatar
rotorhead
Stiffer springs may hold boost better up top. I wouldn't say that the spring doesn't matter at all... depends on your setup.
