20b rx8 update
Old 11-25-07, 10:12 AM
stickmantijuana's Avatar
20b rx8 update
enjoy!
Old 11-25-07, 10:31 AM
Lapping = Fapping
Jeff20B's Avatar
Oh man!
Old 11-25-07, 10:43 AM
Japan2LA's Avatar
I like!!!!!
More pics...Please!!!
I want to see more pics of the exhaust manifold setup...
Old 11-25-07, 11:30 AM
Registered User
justturbo2's Avatar
dam that's nice. post more pics. looks awsome
Old 11-25-07, 11:40 AM
dsaggy187's Avatar
that is very nice
Old 11-25-07, 12:51 PM
thanks guys, here are a few more.
i'll post more pics once i get my car back!!
LIM:
placement:
custom oil pan with baffles:
Old 11-25-07, 01:48 PM
rotary noob
efranklin's Avatar
is that at mazsport?
Old 11-25-07, 01:51 PM
yep mazsport
Old 11-25-07, 01:53 PM
Japan2LA's Avatar
Those new pics dont work...
Old 11-25-07, 02:00 PM
let me try again.
Attached Thumbnails 20b rx8 update-3.jpg   20b rx8 update-5.jpg   20b rx8 update-9.jpg   20b rx8 update-118.jpg   20b rx8 update-attachment-68.jpg
Old 11-25-07, 02:01 PM
first is oil pan with hinged baffles to minimize oil slushing
rest shows the motor position, the turbo, & the LIM.
Old 11-25-07, 02:04 PM
rotary noob
efranklin's Avatar
Originally Posted by stickmantijuana
yep mazsport
sweet, I saw it there.. I wanna see it running though
Old 11-25-07, 02:13 PM
Electric Tape Addict
RockyZ's Avatar
keep us updated! That looks like an awesome project.
Old 11-25-07, 02:31 PM
Eternal_Gamer's Avatar
if the rx-8 came like that, I would of bought one quick. Nice work though.
Old 11-25-07, 02:49 PM
Japan2LA's Avatar
I want to see that exhaust manifold
Old 11-25-07, 03:13 PM
diabolical1's Avatar
still love it. how close are you to ignition?
i just looked up Mazsport, it turns out they are right next door to me. i think i may roll by there next week sometime and check them out.
Old 11-25-07, 03:15 PM
exhaust manifold is just a expanding tube that connects to all 3 exhaust ports.
there was no room for 3-->1 piping. if you look at the DP, you can see that it's almost touching even the simple tubular exhaust manifold.
i don't have any more photos at this time tho.
Old 11-25-07, 03:16 PM
you may want to visit later. they're pretty busy right now and the car isn't even started yet.
Old 11-25-07, 07:20 PM
Rx7 Wagon
Narfle's Avatar
Your belts and radiator are going to be PISSED about the turbo placement. Is it a full drag car?
Old 11-25-07, 07:24 PM
should be no problem with some insulation. i've had hot side of turbo run right next to plastic engine covers for months with no problem. and that was without the jacket.
Old 11-26-07, 04:04 PM
C088
BLK FC3S's Avatar
Looks like you might have some problems with the upper radiator hose when it comes time. Your Alt. is right above it and then it runs right over the hot side of the turbo. Maybe if you wrap the turbo it might be ok but it can't last too long.
Old 11-26-07, 05:46 PM
obviously, won't be routing the pipe over the hot side. if you noticed, the oem water pump assembly was taken out because alternator was moved to the side. electric water pump is going in soon which'd give some freedome as to where the pipe would run. also those radiator inlet & outlet will probably be repositioned.
Old 11-27-07, 06:27 AM
felix_is_alive's Avatar
wow ...looks real good , whta drivetrain are you using , and how much power will you be making?
Old 11-27-07, 11:20 PM
using T2 tranny.
it'll be street driven, so not looking to make heaps of power right now.. probably will stay around 400whp'ish... maybe 500whp.
i'll boost it up later once i'm settled with that power... but for now, i think 500whp would be more than enough for me to handle even on a drag strip nevermind a road course.
Old 11-28-07, 11:04 AM
****** of disaster
thetech's Avatar
FWIW I've had no problems on my RX8 with a 13B-RE motor making over 400rwhp with the stock 6speed transmission.
