S4 to S5 questions
Old Nov 24, 2007 | 09:00 PM
LSD-Ryu's Avatar
DJ Touch #1 fan
S4 to S5 questions
Recently when my rear end in my 88 n/a went out, I went to the local yard and was able to get a very nice driveshaft and joints from an S5 n/a.
Question is that the joints and driveshaft went right in, and everything ran extremely smooth, however there's a very loud THUD whenever the throttle engages. Or from what I can tell, every time the driveshaft turns suddenly.
I'm thinking about purchasing a tii s4 tranny, and differential. Should I just get the S5 tii tranny? Will I have to do a lot of modifications to fit it? The setup if I do that will be an S5 TII tranny, S5 N/A Driveshaft, and S5 Differential. Any opinions on this?
Old Nov 24, 2007 | 09:06 PM
phoenix7's Avatar
check your front diff mount first
make your thread title a little more detailed. "S4 to S5" is so common it might be ignored. "Loud thump when clutch is released" is a better thread title.
Old Nov 24, 2007 | 09:08 PM
LSD-Ryu's Avatar
DJ Touch #1 fan
I think someone told me this. And I did, seems to be in tact, no signs of hard wear. I don't think it's going to give out on me. At least not for the time being. I'm not sure the noises I'm hearing is caused by that.
Old Nov 24, 2007 | 09:11 PM
phoenix7's Avatar
you've gotten underneath and checked for play? Or did you do a visual check?
Old Nov 24, 2007 | 10:04 PM
dirteeboy808's Avatar
it's to hard assess visually......mine looked fine when looking at it , but once removed it was split in two.....It's worth the change.....no more thudding when changing gears and power isn't wasted
Old Nov 25, 2007 | 12:12 AM
LSD-Ryu's Avatar
DJ Touch #1 fan
Just removed it and played with it a bit and yeah it's not looking good. I'm gonna pick one up off mazdatrix. Next question is the transmission issue... wat kinda issues am I looking at if I get a S4 TII tranny and run it with a S5 N/A driveshaft?
Old Nov 25, 2007 | 12:28 AM
phoenix7's Avatar
you using the NA rear end? use the Mazdatrix TII TRANNY--->NA REAR END DS. If you eventually plan to go turbo then you might as well get the TII rear end and DS.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
