TPS Adjustment - Quick question
Old Nov 24, 2007 | 10:03 AM
Hazard15301's Avatar
Rotor Junkie
This is the procedure I'm referring to here. Under diagnostics, step #1 says to hold the engine at 2k rpms. It never says to shut the engine off. Am I correct in assuming that you leave the engine on for the entire procedure? If so, do you have to hold it at 2k the whole time?? Thanks.
Old Nov 24, 2007 | 10:11 AM
ibrakestuff's Avatar
hondas suck hard
no u just have the engine running to conferm that the ecu is receiving the signal properly, that what step one is doing i believe.
step 2 u do with engine warmed up to operating temp, with engine off.
Old Nov 24, 2007 | 01:02 PM
Rotor Junkie
Well thanks for the info, however the TPS doesn't even matter. I checked my compression and it ain't lookin good. 80-80-60 on the front, 30-35-30 on the back. Woohoo. I'm gonna go shoot myself now.
smikels
Rtek Forum
May 12, 2016 12:34 AM
Microtech
30
Apr 23, 2016 06:37 PM
incubuseva
14
Sep 3, 2015 12:37 PM
eddierotary
Aug 16, 2015 04:12 PM
