trouble with reverse lights
Old Nov 23, 2007 | 09:59 PM
b20triz's Avatar
my reverse lights stopped working, or i think they did. when i first got the fc about 1.5 months, the reverse lights would work... every now and then. now they dont work at all. i checked the bulbs, and the wiring in the back looks fine. is there a fuse i can look for? i checked the fuse box under the driver dash and i didnt find any light fuse it could be. help please.
TIA, tristan.
Old Nov 23, 2007 | 10:43 PM
NZConvertible's Avatar
I'm a boost creep...
The reverse lights are fed from the METER fuse, so if your gauges are working then the fuse is not the problem. Most likely it's a flakey 5th/reverse switch on the gearbox, or it might just be a switch's wiring.
Have a look at the switch's location in the FSM Manual Transmission chapter. If you don't have the FSM, click here and download it in PDF format for free.
Old Nov 23, 2007 | 11:46 PM
t24todd's Avatar
RE_p Rotors
a man there is alot on this just search should bring you up a bunch...had the same prob finnaly relized that it was my actual switch after testing...might be you prob too..t2 and na are NOT the same..and s4/s5 are different too..you can go with the j spec swich which is just shorter..
Old Nov 24, 2007 | 12:03 AM
88rxn/a's Avatar
tom port.. AKA streetport
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/write-up-reverse-5th-transmission-switch-fix-690555/
BAM!
Old Nov 24, 2007 | 04:27 PM
If the switch is already bad, wiring in a relay won't help...
Old Nov 24, 2007 | 05:20 PM
HAILERS's Avatar
HAILERS
Wiggle the shifter in and out of reverse and have someone look at the reverse lights. If they come on briefly, it's likely the switch on the transmission. Check for 12vdc on the switch wire. Don't ask me which of the wires. I forgot.
Old Nov 24, 2007 | 07:04 PM
vrracing's Avatar
reverse switches
Are they a pain to find if they are bad? Any sources beyond e-bay and the items for sale forum?
Old Nov 24, 2007 | 07:27 PM
Cleva Locc Dogg's Avatar
Maniac 7
if they use to work, check the connector that goes to the tranny... maybe it was barely connecting, then just unplugged itself
Old Nov 24, 2007 | 10:03 PM
b20triz's Avatar
to find that do i have to take out the the shift boot? or will i see it in the egine bay? under the car? cant find it.
Old Nov 24, 2007 | 10:47 PM
Did you look in the FSM like I said?
Old Nov 25, 2007 | 12:10 PM
88rxn/a's Avatar
assuming the switch is working off and on random...this will fix it....ive fixed 2 cars doing this...
Old Dec 3, 2007 | 03:28 PM
b20triz's Avatar
thanks guys, for all your help!
Old Dec 3, 2007 | 03:49 PM
88rxn/a's Avatar
so you fixed it??
if so how?
bigtuna
Oct 8, 2015 10:01 PM
The1Sun
Sep 15, 2015 04:45 PM
ls1swap
15
Sep 8, 2015 05:30 PM
The1Sun
Sep 7, 2015 10:21 PM
