how to convert an non turbo rx7 into an turbo
Old Nov 22, 2007 | 08:38 PM
MarcFC3S's Avatar
i love my 88 rx7
and i was thinking of just buying a swap off an jdm engine warehouse but i want to know if motor mounts are different
and also want to noe wat else is different and wat i will have to change?????
if u could help me i would appreciate iy=]
and its my first rx7 and i want it to run already!
Old Nov 23, 2007 | 12:05 AM
PercentSevenC's Avatar
I need a new user title
Go to the second gen section FAQ (found here). There are all sorts of things for you to read there. Do lots and lots of searching, for terms like "na turbo conversion". Once you've done that, then ask any specific questions you still have.
Good luck, welcome, and happy searching.
Old Dec 3, 2007 | 09:59 PM
NoviceRotaryTech.'s Avatar
Home-brew Rotary
Why doesn't it run?
If its a simple fix / minor damage, fix it.
If the motors blown with bad coolant or oil seals, or for some odd reason bad comp. seals or springs, aka major damage, an you dont want to go through a rebuild, then I can see going with a turbo swap.
Theres nothing wrong with / bad about an n/a rotary.
Old Dec 15, 2007 | 04:50 PM
13b_soldier's Avatar
Pop-A-pop!
I love the High Compression NA 13b.
Old Dec 16, 2007 | 03:54 PM
diabolical1's Avatar
not trying to be mean, really i'm not, but if you're asking those questions, you're nowhere near ready to being able to complete this swap correctly. fix the car as is and drive it while learning what you need to know.
cam_7779
Aug 18, 2015 07:48 AM
Turblown
Aug 14, 2015 04:48 PM
Sharkbait24
Aug 12, 2015 10:36 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
