Whats this wire
Old Nov 22, 2007 | 07:50 PM
rotarheadjr.69's Avatar
Whats this wire
I have a sensor on top of my thermostat housing. I know about the temp sending unit for the gauge. I know about the temp sensor for the ecu. But what is this single wire that goes to a what looks like another temp sender. It only has one wire. Also, this wire appears to have been hot at one time. I recently got the car and do not know what the history is besides rode hard and put up wet. I am new and any help would be appreciated.
Old Nov 22, 2007 | 07:55 PM
Turbo7MN's Avatar
S4 is sexay!
What year is the car?
If I'm thinking of the same wire it is for another temp sensor that was only on cars equipped with an automatic transmission.
Old Nov 22, 2007 | 08:13 PM
NZConvertible's Avatar
I'm a boost creep...
It's the temp switch for the auxiliary electric fan in front of the AC condesnsor. The switch turns the fan on if coolant temp gets up to 207degF. The fan also runs when the AC is turned on.
Old Nov 22, 2007 | 10:01 PM
pfsantos's Avatar
(blank)
^ Exactly. Fan thermostat switch.
Old Nov 23, 2007 | 11:18 AM
HAILERS's Avatar
HAILERS
If you have an aux fan, and the key is ON , and you pull that green/black wire off the temp switch, the aux fan should come on.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
