Dammit i am gonna sell it!!!
Old Nov 21, 2007 | 12:57 AM
re-rx7's Avatar
Vp in charge of Girls
My damn car has still not quit it's hesitating and jerking. I changed the fuel pump, grounds and everything.....Anybody else have any suggestions!!!!
Old Nov 21, 2007 | 01:34 AM
Sindregutt's Avatar
MAF working? Injectors okey?
Nice signature
Old Nov 21, 2007 | 01:41 AM
re-rx7's Avatar
Greddy primary's, rc engineering sec, all 720cc
Old Nov 21, 2007 | 02:09 AM
scrip7's Avatar
Rotary Gearhead
I had a similar issue with my NA. After doing the usual tests, tps, vac leaks, etc. I grabbed my lab scope and looked at the volts sweep of my pressure sensor at different throttle angles and found a consistent glitch just above idle. Grabbed a known-good sensor and Voila!....no more bucking. Other things can cause it, such as fuel pressure, tps, AFM, and 87 octane shitty gas from 7-11.
Old Nov 21, 2007 | 02:51 AM
re-rx7's Avatar
It's been a gradual problem that i thought i fixed. then right back it came. i have a s4 pressure sensor don't think it will work though.
Old Nov 21, 2007 | 02:50 PM
fc3s1.3b's Avatar
rotary + turbo= **)
ive had the same problem with my 10th anny. i changed the ground from the battery to the engine(right behind the oil filter) and the ground right next to the windshield wiper motor that goes to the engine. but then my hesitation came back. but if u havent changed those grounds it might work for u. my hesitation is at 5500 rpm and it only happens about every other time. i dont know if urs it at the same spot or not. so if u figure out anything could u pm me and let me know what u did to fix it.
Old Nov 21, 2007 | 04:38 PM
V8slayer's Avatar
Tire Smoken Tandm Gambler
dont tell a Rx7 club you wanna sell your car unless you are serious
Old Nov 21, 2007 | 04:42 PM
boostedfc3s's Avatar
1.3 liter piston eater
I don't know about the rest of you but I have never been so frustrated with my 7 that I even thought about selling it. That's just wrong IMO.
Old Nov 21, 2007 | 04:46 PM
veedubbed's Avatar
What do you have controlling those? If you have nothing besides the stock ECU and 720's in the primaries, then there is your problem.
Old Nov 21, 2007 | 05:32 PM
re-rx7's Avatar
i have a safc neo. Awaiting my install date for my haltec
Old Nov 21, 2007 | 05:42 PM
veedubbed's Avatar
Do you have the fuel map tuned well enough? Too much/too little fuel will cause it buck and jerk. Does it do it under acceleration? Under boost?
Old Nov 21, 2007 | 06:04 PM
phoenix7's Avatar
i'll give you 20 bux shipped for it.
have you checked your TPS? MAF?
Old Nov 21, 2007 | 06:50 PM
re-rx7's Avatar
sold hahaha!!!iam not getting any check engine lights. My safc says that tps sensor voltage is .85 and tops out at 4.2 wot. Just wired the fuel pump to the battery so i know it's getting good voltage. Also i looked at some wires that sit by the trailing ignition that looked like they are hooked up to some relays??? what are these relays??
Old Nov 21, 2007 | 07:02 PM
R3N5LOW's Avatar
are you running the stock ecu?
Old Nov 21, 2007 | 07:03 PM
veedubbed's Avatar
Once again, does your SAFC have a good tune on it? With 720's in the primaries you will need to pull fuel throughout the entire range in order for it to not run pig rich and buck around on you.
Old Nov 21, 2007 | 07:07 PM
re-rx7's Avatar
yea my wideband is showing lean as hell. i can watch it go lean. it was fine before for like 3 months it justt started this **** not to long agol( 1 week)
Old Nov 21, 2007 | 07:13 PM
veedubbed's Avatar
"Lean as hell" will make it buck around a ton too. Try adding some more fuel. Don't take it into boost if it is leaning out, unless you want to do a rebuild anytime soon.
Old Nov 21, 2007 | 07:15 PM
re-rx7's Avatar
yea i haven't. I jus can't figure out why it is doiing this.
Old Nov 21, 2007 | 07:56 PM
phoenix7's Avatar
post some pics and video
Old Nov 21, 2007 | 08:17 PM
Tessai's Avatar
What will I drive next?
Hey man, remember my red turbo I brought to a few meets? It had a bad TPS and did that sometimes... check that.
Old Nov 21, 2007 | 08:25 PM
re-rx7's Avatar
hhmm yes i wil do.Tessai where the hell have you been man?
Old Nov 21, 2007 | 08:46 PM
Tessai's Avatar
I totally forgot about the meet this month. The GF and I went to a movie, and after we got out we both went "****, the meet was tonight!" .
Better luck next time?
And I'll bring those center caps!
Old Nov 21, 2007 | 09:22 PM
fc3s63tx's Avatar
Running it lean like that will detonate your engine. Check your tune and see. Do you have a wb?
Old Nov 21, 2007 | 10:42 PM
RX7freak08's Avatar
Wish he had a running rx7
The center caps for the vert wheels. I believe re-rx7 wanted those for me but i dont know.
Old Nov 21, 2007 | 11:46 PM
xeccentric's Avatar
Non-op
at least your car starts >_>
