Pics of STOCK FMOC
Old Nov 20, 2007 | 11:53 PM
orion84gsl's Avatar
My 7 is my girlfriend.
Pics of STOCK FMOC
As it says, I'm looking for pics of the stock 1st gen fmoc mounting. I have done some searching, but come up empty handed and now I'm sleepy. I'm going to start working on remounting my converted cooler to a more vertical position, and I would prefer to use the stock mounts rather than make my own, if all I need is a different AN fitting. Otherwise it's off to the Metal Superstore. Thanks in advance.
Old Nov 21, 2007 | 12:36 AM
Slammed_GSL's Avatar
The stock S2/S3 oil coolers require a 3 row short radiator, mounts hang directly below the radiator. about 36$ for a pair.
Mazda still sells the stock mounts.....like 3 years ago.
Go with a FC oil cooler, the FB bungs crack and leak.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/anyone-have-fc-oil-cooler-fb-pics-417817/
http://www.pbandjracing.com/oil_cooler_pics.html
Old Nov 21, 2007 | 07:44 AM
dominicaneddy's Avatar
www.ostcbpt.com
so if you have a 1st gen the 2nd gen will bolt right up using the 1st gen radiator?
Old Nov 21, 2007 | 08:16 AM
Siraniko's Avatar
RX for fun
no. if you mount it below the radiator, there will be a large gap as the FC OC has a bung on top plus you have to modify the mounts. However, you can install it in front of the radiator.
Old Nov 21, 2007 | 09:14 AM
orion84gsl's Avatar
Well I already have what I believe is an SE cooler. But I just needed a visual, although if they belong under the rad then I can't do it that way, as I have a taller than OEM rad. Thanks
Old Nov 21, 2007 | 10:22 AM
dj55b's Avatar
Ya the coolers in stock form bolt directily under the rad ... looked it up in one of the few pictures online.
Old Nov 21, 2007 | 10:23 AM
Siraniko's Avatar
RX for fun
In addition to the brackets, the angles of GSL-SE OC is different from a under-the-rad-OC
Old Nov 21, 2007 | 11:05 AM
trochoid's Avatar
Old Fart Young at Heart
Go back and review the write up up I did that's in the archives. The way in which the muffler clamps are mounted can be varied in a variety of configureations, enabling one to work around both the PS loop line ad the AC condensor.
I've found that even with using the 2nd gen banjo fittings, the radiator shroud will still need to be trimmed. Since the mounting points are different between the 2 generations, one needs to get creative on mounting and hose routing.
Old Nov 21, 2007 | 04:26 PM
dayton's Avatar
under construction
i used the rad. and fmoc from a 81-82 body for my conversion... worked out great...
