Diff. on 12a rotors front and rear?
Old Nov 20, 2007 | 10:51 PM
ultimatejay's Avatar
On a 12a is the front and rear rotor different or are they interchangeable. And if they are diff. how do you tell them appart?
Thanks, I have searched but could not find anything.
Old Nov 20, 2007 | 11:09 PM
waysrx7's Avatar
Apathy Isn't Laziness
If you look at the pic you see the combustion bowl, if you switch a front rotor with a rear rotor, the bowl will be upsidedown.
Not interchangeable.
To tell if it's a front or rear rotor you have to know which side the gear is on.
I can't remember off the top of my head by I can let you know tomorrow unless someone else already has.
Old Nov 21, 2007 | 12:30 AM
Jeff20B's Avatar
Lapping = Fapping
You have an '83 to '85 rotor sitting there.
Old Nov 21, 2007 | 12:49 AM
waysrx7's Avatar
Sure do. It's an '85. I don't think I've seen pre '83, what do they look like?
Old Nov 21, 2007 | 02:31 AM
twistystraw's Avatar
young rotorhead
sorry for the noob question but how can you tell?
Old Nov 21, 2007 | 08:18 AM
blwfly's Avatar
kiwi from downunder..
iirc
combustion bowel is a little narrower
and the "f" "r" lettering is diff.
Old Nov 21, 2007 | 10:17 AM
Jeff20B's Avatar
Lapping = Fapping
It has an N and a large cast R. The N means '83-'85.
Old Nov 21, 2007 | 07:27 PM
waysrx7's Avatar
This is a rear rotor. The gear is on the right side so when it is rotating in the engine the bottom or larger part of the bowl reaches the combustion chamber first.
A front rotor will have the gear on the opposite side.
Old Nov 21, 2007 | 10:58 PM
Thanks guys for the help. I am tearing down my first rotary tomorrow. So the larger bowl is always facing down towards the oil pan.
Old Nov 22, 2007 | 01:32 AM
young rotorhead
Woah sweet i never knew they put imprints into the bowls. Is it typical to have that much build up on the rotor?
Old Nov 22, 2007 | 01:46 AM
dj55b's Avatar
acumulated over 22+ years yes ... take the rotor face onto a wire brush attachement on a grinder and should take care of it all. Make sure the wire bruch is brass to not hurt the surface.
Old Nov 22, 2007 | 01:59 PM
Just got done Dissasembling my 12a. Took about an hour. The front hub bolt was a little tight and the rear stat gear was a biotch to get out. Took one hour and that was fighting sticking components like the dowl pins- I need to make a tool for that.
Quick question. I only have one apex seal spring for each apex seal. Is this normal on 12a's? On the 13b's I know they have two springs- one small and one larger one for each apex.
Old Nov 22, 2007 | 02:01 PM
Jeff20B's Avatar
Lapping = Fapping
3mm seals use one spring.
Old Nov 23, 2007 | 09:25 PM
Thank you. I figured as much because there is only 1 ridge on each side of the seal but I wanted to make sure.
tsmith94FD
Aug 16, 2015 05:41 PM
