Boost spike with open wastegate and AVCR
Old Nov 20, 2007 | 06:09 PM
turBRO240's Avatar
Certified Rotorhead
The "A" setting on my AVCR is set to 14psi and when I got WOT in second for example up until 8500, i look at my peak hold and its 1.28 bar which is 18psi.
I have a HKS standard wastegate vented to atmosphere with a small pipe, so there really is no restriction in exhaust flow, but shouldnt the AVCR keep it at 14psi?
comments?/ideas?/opinions?
Old Nov 20, 2007 | 07:00 PM
AMRX7's Avatar
What is your gain setting? If it is too high it will spike. Does it only do this in 2nd gear?
-Andy
Old Nov 20, 2007 | 07:35 PM
turBRO240's Avatar
Certified Rotorhead
Not sure... ill try to check soon.
And in all gears.
Old Nov 20, 2007 | 09:49 PM
AMRX7's Avatar
Then it is probably the gain. You set a % for that and the target boost. Leave the target boost where you want it, and reduce the gain% until it stops overshooting.
-Andy
Old Nov 21, 2007 | 03:18 AM
RETed's Avatar
WG too small.
-Ted
Old Nov 21, 2007 | 12:52 PM
AMRX7's Avatar
Right it could be that your WG is too small as well, the easy test is to turn the boost controller off and see what boost you get. What is the spring in the WG?
-Andy
Old Nov 21, 2007 | 01:35 PM
turBRO240's Avatar
Certified Rotorhead
Its the 40mm HKS Standard with a 12psi spring.
Ill try WOT with it off and see what happens.... i use to drive around with it off so it stays at 12psi but i remeber it boosted higher then that.
Old Nov 22, 2007 | 10:35 PM
mono4lamar's Avatar
In the burnout box...
The avcr is a very wild tool. It's a great controller if you have the time and patience to set it up correctly...
Old Nov 23, 2007 | 02:29 AM
turBRO240's Avatar
Certified Rotorhead
Indeed. Im going to have Kan setup mine soon.
Old Nov 24, 2007 | 06:17 PM
cewrx7r1's Avatar
Eye In The Sky
If you take the pressure source for the boost solenoid directly on the turbo outlet, it will spike more and will require a low gain value.
I had this problem with my Blitz DSBC R model. When I moved the source to the Greddy elbow, the problem went away and boost was manageable.
Old Nov 24, 2007 | 09:38 PM
turBRO240's Avatar
Certified Rotorhead
My vaccum source is right on the compressor outlet.... nice call Chuck.
Old Nov 25, 2007 | 12:22 AM
mono4lamar's Avatar
So I'm taking you moved it further down stream? I'm in the midst of installing an avcr on an sti with a fp green turbo. I'm just trying to add some others experiences to my memory
Old Nov 25, 2007 | 12:41 AM
turBRO240's Avatar
Certified Rotorhead
Where is the optimum location?
Old Nov 25, 2007 | 10:47 AM
mono4lamar's Avatar
I would think on the intake manifold. That's what my avcr manual states...
Old Nov 26, 2007 | 10:41 AM
arghx's Avatar
rotorhead
AVCR is notorious for being difficult to use
Old Nov 26, 2007 | 12:32 PM
turBRO240's Avatar
Certified Rotorhead
But its one hell of a boost controller.
Im thinking of putting it on the underside of the GReddy elbow. Is close to the throttle body OK?
Old Nov 26, 2007 | 12:40 PM
AMRX7's Avatar
Interesting, I have my solenoid source only a few inches after the compressor outlet, and the AVC-R boost sensor off of the UIM. I don't have any spike issues. At one point I moved the solenoid source over to the UIM as well, but had spike issues. However, I didn't play around with the gain value to compensate for that change, though I'd assume I would have had to lower it. This seems opposite to your experience?
-Andy
Old Nov 26, 2007 | 05:39 PM
turBRO240's Avatar
Certified Rotorhead
My turbo seems to leaking some oil from the exhaust side ... could this be a symptom of boost spike?
I dont nkow what to do... either sell it and get a new turbo (GT35R), or rebuild it
Old Nov 27, 2007 | 12:09 AM
arghx's Avatar
rotorhead
are you sure it's not just a leaky oil feed line?
Old Nov 27, 2007 | 01:22 PM
turBRO240's Avatar
Certified Rotorhead
It dosnt seem like it is.... but theres smoke coming from the exhaust side of the turbo and i can deffinatly smell it.
My rotary mechanic says the exhaust oil seal is leaking just like on his T04R.. so i dono... it happened 2 weeks ago... didnt happen at all, all of last week (even when really pushing it)... and now this week its smoking again. I dono what to think, or do.
If someone would buy my kit, I want to go 500R, or else ill have to get a rebuild or GT35R
Old Dec 2, 2007 | 11:06 AM
cliprun's Avatar
check your intake manifold
Old Dec 3, 2007 | 03:49 PM
dragonxbreath's Avatar
just being curious...but what else could possibly cause boost spike on a single turbo setup? Just curious?
Old Dec 3, 2007 | 07:54 PM
turBRO240's Avatar
Certified Rotorhead
malfunctioning of the wastegate or boost controller.
Old Dec 13, 2007 | 02:17 PM
so my car just started boost spiking. I have a RX6b, so no wastegate there. I also have the AVC-R and haven't touched it. And at the same time my EGT are reaching 800c. I thought it was a vac line at first but everything is still the same. Any suggestions on where I should look for this. Oh and the boost spiking occurs even with the AVC-R on the off posistion.
Old Dec 13, 2007 | 02:30 PM
0110-M-P's Avatar
Too Many Projects
I wouldn't put it on the underside of any intake piping. If you get oil residue in any of your pipes from a leaking turbo thrust bearing or something else then it could settle in the vacuum hose and make the MAP sensor read incorrectly. Probably wouldn't happen, but definitely possible.
