Help ASAP!!! Car is flooooooood!!
Old Apr 12, 2002 | 12:19 PM
serge1's Avatar
Ok I found the problem. The car is flooooodddddd!!!
Any advice on how to correct this???
I removed the plug and dryed them but the car immediately flood the plug again.
Serge
Old Apr 12, 2002 | 12:24 PM
Import Convert's Avatar
Remove the plugs and the EGI fuse. Crank the engine with the starter for 10 secs or so and repeat a couple times. Replace plugs and fuse. Hopefully it should start.
Old Apr 12, 2002 | 12:25 PM
Oh, you may or may not have to hold the gas pedal down. I'm not sure on that one. Lots of people say you do, while some say don't.
ttpowerd's Avatar
HARRRRRRRRR
you could also do the atf trick which is the same as above just put a teaspoon of atf in each of the 4 plug holes.
Old Apr 12, 2002 | 12:26 PM
ttpowerd's Avatar
HARRRRRRRRR
yes push the gas pedal down while you are turning the engine over
Old Apr 12, 2002 | 12:27 PM
Johnny's Avatar
OG
yup... exactly the thing to do....
Just like if you would have searched and read the samething serge !
