Megasquirt Launch Control
Old Nov 12, 2007 | 04:20 PM
SpecFC's Avatar
SOUL-LESS
Launch Control
Hi,
So im trying to setup launch control on my MS1 V3.0. However, I can't seem to find any pictures of the circuit needed to do this, or which pin on the DB37 is the input for the clutch switch.
So, can someone please enlighten me?
Old Nov 12, 2007 | 04:35 PM
muythaibxr's Avatar
MegaSquirt Mod
http://www.msextra.com/manuals/MS_Ex...al.htm#launchC
Ken
Old Nov 12, 2007 | 04:45 PM
SpecFC's Avatar
SOUL-LESS
So, am i not even going through the DB37 then?
Old Nov 12, 2007 | 07:15 PM
toplessFC3Sman's Avatar
you can run it through the DB37, since there are pins that arent being used, such as the ones for the idle air stepper valve (i think, there are 4 interspersed in the bottom row of the DB37), and a few other spare pins that you have probably already run spark through.
However, it isnt already connected to the DB37, so you'll need to run a jumper from the appropriate hole on the underside of the board to that pin.
Old Nov 12, 2007 | 11:22 PM
SpecFC's Avatar
SOUL-LESS
ok, thanks
Old Nov 13, 2007 | 05:30 PM
SpecFC's Avatar
SOUL-LESS
So, in that diagram, it says to use 1N4001GICT-ND diodes, I have some 1N4001DICT-ND, and some 1N5819DICT-ND laying around, can i use these?
Old Nov 13, 2007 | 05:43 PM
muythaibxr's Avatar
MegaSquirt Mod
The 1n4001DICT-ND should be ok.
Old Nov 13, 2007 | 05:53 PM
SpecFC's Avatar
SOUL-LESS
Great, thanks
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
Heedlessone
Sep 16, 2015 11:31 AM
