whats the fastest turbo2 with stock turbo have u seen
Old Nov 9, 2007 | 10:18 AM
rotormind's Avatar
a friend of mind has a turbo2 with a stock turbo and ran a 13.1 @106mph. with a 2.1 60ft. here are his mods
halteck f9 (very old stuff) using the stock computer for timing
straight 3'' exhaust
stock primaries and 680cc secondary injectors
front mount Greddy intercooler
streetported turbo2 center plate, and believe it or not, 6port side plates
no boost controller, he ported the waist gate and the turbo wont go pass 12psi
and the car is still rich. afr are in the 9s. hes scared to lean it out
forgot what kinda clutch he using, but thats upgraded as well
i was there and i saw it for myself and drove in the car plenty of times. the car is so responsive and still has fair top end.
has anyone seen one faster or close to this?
Old Nov 9, 2007 | 10:25 AM
RotaryResurrection's Avatar
12.8 @ 108 IIRC, on one of my large streetport 3mm seal s4 turbo engines. No emissions, stock turbo and IC, full exhaust and intake, FCD, fuelpump, forget what boost he was running but somewhere in the 12-15psi range IIRC. The setup didn't last long before he broke the rear iron dowel land in 3 spots launching at the track. Obviously he didn't really have supporting fuel/computer mods necessary for the power, but it did hold up for 3 or 4k hard miles.
Old Nov 9, 2007 | 10:45 AM
rotormind's Avatar
well my friend has been beating the hell out the car, and no problem so far, at one point he was driving it to work everyday because his other car broke down. but he stop because it waist too much gas. i dont think it should break because its running so rich, and only boosting 12psi at most. but u never know. also i wish i had a picture of the intake he made from some honda cold air intake pipe. hes sucking air from out side next to his intercooler pipes
Old Nov 9, 2007 | 11:05 AM
Shainiac's Avatar
Is that with a S4 or S5 turbo?
Old Nov 9, 2007 | 11:09 AM
RETed's Avatar
One of the old TeamFC3S guys ran a 12.7 a long time ago...
What's the point of this thread?
-Ted
Old Nov 9, 2007 | 11:16 AM
rotormind's Avatar
he brought the turbo used off of ebay. not really sure. ive heard that the s5 turbo was a little better. can u tell the difference by sight
i brought this thread up because it seems know one on here is running stock turbos and i heard alot of people say that there too restrictive to make any power. and also to bring up the fact that it is a very cheap way to make a good amount of power
also its pretty fun to drive a car this fast on the stock turbo. almost no lag at all
Old Nov 9, 2007 | 11:42 AM
umi415's Avatar
First statement is incorrect, my 7 ran with the stock turbo until this year. I simply wanted more power. Stock turbo is only good for about 250whp. Since the rotary engine has so much potential, Why would you keep it at that power level?
just my .02
JP
Old Nov 9, 2007 | 11:45 AM
umi415's Avatar
Its alot more fun when you put in a bigger turbo trust me!
Old Nov 9, 2007 | 11:46 AM
rotormind's Avatar
just for people who are on a low budget. im not saying that a stock turbo is the best way to go. it just has its benefits
Old Nov 9, 2007 | 11:50 AM
umi415's Avatar
I guess so
Old Nov 9, 2007 | 12:21 PM
rotormind's Avatar
i wanna see what it would do when he get it properly tuned and hopefully a better launch
Old Nov 9, 2007 | 01:34 PM
umi415's Avatar
not much better than that, he is basically maxed out
Old Nov 9, 2007 | 02:22 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
my TII's previous owner claimed he ran 12.6 s quarter mile on the stock turbo..
before i upgraded the turbo, i had it dyno'd and it made 249 whp on a dynomite dyno (reads similar to a mustang dyno). 3" exhaust, RA rebuild, 750cc/1000cc injectors, rtek 2.0, fmic, ported intake manifolds, tb mod, and stock turbo with boost dropping to 7 psi near redline
Old Nov 9, 2007 | 02:40 PM
I have heard of people making 275-280rwhp on the stock turbo.
Old Nov 9, 2007 | 02:45 PM
rotormind's Avatar
to run lets say a 12.5 at 108, what kinda power r u looking at for the weight of these cars
Old Nov 9, 2007 | 03:46 PM
Silverfc88's Avatar
Closer to 300 to be consistent.
Old Nov 10, 2007 | 03:18 AM
ZAN_TUNING's Avatar
Just turn up the boost!
300? nah.. we were running 13.0's w/ 2.3 60ft's with only 240rwhp heavier than stock. there is a certain drifter making very close to 300rwhp on a bone stock turbo.
you would be suprised at what a good engine can do with one of these little snails.
Old Nov 10, 2007 | 11:13 PM
junito1's Avatar
F**K THE SYSTEM!!
our little snail arent so little compared to other stock turbos. Aint it a rather big
t3? the exhaust housing ,anyways, looks bigger than regular t3's
Old Nov 12, 2007 | 02:01 AM
ZAN_TUNING's Avatar
the compressor isn't really any bigger than some stock turbos... but yes the turbine housing is large, altho not a T3.
Old Nov 12, 2007 | 08:52 PM
2Fierce's Avatar
Cautious Angel
i tried to search, and failed...but
what is the compressor and inlet/outlet sizes for the stock turbo? (s4 model)
thank you
Old Nov 13, 2007 | 01:48 AM
ZAN_TUNING's Avatar
hell i can't remember off the top of my head, but if i get a spare moment today i'll bust one open and measure it real quick.
Old Nov 13, 2007 | 09:09 AM
gxl90rx7's Avatar
stock inlet is 1.75" with 2" outlet
Old Nov 13, 2007 | 11:58 AM
ZAN_TUNING's Avatar
oh i thought he was refering to the inducer/ exducer
Old Nov 13, 2007 | 06:02 PM
junito1's Avatar
F**K THE SYSTEM!!
so if the exhaust housing is larger than a t3... how big is it?
Old Nov 13, 2007 | 08:36 PM
arghx's Avatar
rotorhead
I've never seen actual measurements of the stock turbo, just speculation. And thus it's hard to compare our stock Hitachi turbo to Garrett T series turbos.
