Installing single din cd player in fc.
Old Apr 11, 2002 | 08:29 PM
rxspd's Avatar
Hey, Im installing a clarion single din cd player in my fc, it has no mounts whatsoever, and the wiring harnesses have been cut, can somone give me some direction, as to what i need to buy to install it, and make everything closed off, where it looks neat. mounting kit? And what wires work as what.
Thanks, Jason
Old Apr 12, 2002 | 07:22 AM
sunshine's Avatar
I just got a clarion from Crutchfield...they sent me a wiring kit that acts as a "bridge" between the stock harness and the clarion harness. They also sent a plastic mounting kit. The kit has to be assembled, but look very pro after its in the dash.
Which harness has been cut? The FC's of the Clarions?
Old Apr 12, 2002 | 09:39 AM
The plastic mounting kit is a piece of crap... I'm completely fed up with it. The instructions suck too.
Old Apr 12, 2002 | 09:44 AM
sunshine's Avatar
Ur rite on the instructions, they do suck ***. I just sat in my car and took 10 min to figure out which configuration would work best.
Old Apr 12, 2002 | 10:04 AM
You can get the harness and mounting kit from any number of vendors. I got Schoshe, both pieces $4 each, from sounddomain.com. The part numbers can be found by matching your car year and make to the kits available.
The 'space' in my 1990 is wider than din and taller than double din, so it is a nightmare to fit with today's 1 din radios.
Since the wires have been cut on your HU, do you have the plugs that fit into the back of the HU? The mounting sleeve?
I tried an ISO (no sleeve) installation in mine this weekend. It mounted great, but because the hole is so odd shaped, I would've had to spend a bunch of time fabbing a hole filler plate. Also the width was a problem (ISO mounting typically doesn't use the trim ring, either). ISO mounting is like the factory radio, and even uses the factory brackets. Too bad Mazda made the opening so non-standard.
Old Apr 12, 2002 | 10:50 AM
Icemark's Avatar
I normally add a radio pocket (Toyota or Metra for about $15) to a single din so that it becomes a double din radio.
I always ISO mount. Even if that means going to the dealer and buying the mounting brakets. All the aftermarket kits for the FC mount the radio onto the dash bezel, which as you may know gets very brittle with age. So if you mount it to the dash bezel every bump helps break the dash.
using the factory brakets and ISO loading secures the radio as the factory did. Its not too hard to cut out a trim ring with a $30 jigsaw from a piece of $5 plastic that you get from the local stereo, plastic, or home improvment store.
R7rexy
19
Sep 2, 2015 10:24 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
