Heeeeeeeeeeellppp!!! Car don't start!!!!
Old Apr 11, 2002 | 07:16 PM
serge1's Avatar
Hi,
I have installed my Efini Y-pipe (forgot to put a new o-ring) and Apexi Power Intake and The car dont start!!
I have removed the air pump while installing the
Y pipe, Is it possible that I desadjusted the timing
while playing with the belt???????
Please help!!!
Serge
Old Apr 11, 2002 | 07:33 PM
PaulyDee's Avatar
What you installed should have no effect on starting the car or not. What exactly is it doing? Is it cranking, is it trying to fire? Does it sound like the tengine has compression (whoop, whoop , whoop when cranking)?
Paul D
Old Apr 11, 2002 | 07:50 PM
serge1's Avatar
re
When I first started it, The engine turned a quarter and
shutted down. Now the engine turn but nothing happen
even not a spark. Can it be flooded??
Serge
Old Apr 11, 2002 | 07:52 PM
serge1's Avatar
And yes compression is here.
Serge
Old Apr 11, 2002 | 09:10 PM
Ryan95's Avatar
Reset your ECU.
Old Apr 12, 2002 | 01:16 AM
Nameless's Avatar
It might be flooded pull ur plugs and check.
And I dont know if u've heard, but my car wasnt starting, and just a week earlier tested with excellent compression. Turns out O-rings just went bye bye, and coolant was getting in the combustion chamber. Hopefully yours is just flooded. You can reset your ECU as part of the unflooding process as well.
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
torky007
Aug 17, 2015 05:14 PM
