Exhaust over-temp light
Old Nov 7, 2007 | 12:16 PM
dragonxbreath's Avatar
So i have a single apexi rx6 turbo and my exhaust warning light is coming on right around 800C. The other night it came on and my turbo warning light came on right around 6200rpm and caused my engine to stall for a sec, possibly cut the fuel. Can anyone tell me why it's not letting me hit full boost at higher speeds b/c of this warning. Possibly a tuning issue, maybe air/fuel ratio is off. My engine temps are solid however, never reach over 92C. Any help would definitely greatly be appreciated. Oh and the exhaust outlet for my turbo is being dumped next to the cat, could this be causing the overheat as well?
Old Nov 10, 2007 | 01:04 PM
dznutzuk's Avatar
Uncontrollable drifter
Do you by any chance have a power FC?
Old Nov 10, 2007 | 03:40 PM
crazyrx7's Avatar
Big Daddy!!!
I sure ******* hope so other wise by by motor.
R.K.
Old Nov 13, 2007 | 04:21 AM
dznutzuk's Avatar
Yeah well I was asking because the powerfc uses that light for it's own purposes from what I remember.
Old Nov 13, 2007 | 08:55 AM
TRISPEEDFD3S's Avatar
FEED me
Isn't that where our new check engine light is at? HAHA!
Old Nov 13, 2007 | 01:45 PM
I definitely have a Power FC. I alos got it dynoed today. I changed the plugs, and found out i have a cracked plug wire. So that was all changed which is good, but i got a disappointing 338rwhp on the car. Those RX6 turbos aren't that great unless you get an IHI
Old Nov 13, 2007 | 02:59 PM
crazyrx7's Avatar
Big Daddy!!!
They are basically a replacement for the stock twins in terms of power. That turbo kit is the biggest waste of money if you want more power than the twins.
R.K.
Old Nov 13, 2007 | 08:39 PM
lol...yeah i basically figured that out the hard way...i mean, it's so damn expensive and doesn't give u a whole lot of power, T-78 is the way to go maybe
Old Nov 13, 2007 | 08:49 PM
hondahater's Avatar
spending too much money..
do some research. It's all about what kind of responce you want, what kind of power goals you are looking for etc... Lots of people have given up on the t78 and gone with gt seriese turbos because they spool better and they are a newer design. Check out a 500r or gt40r, gt42r. That turbo you have is really small and that is a pretty well known fact, next time do a little research before spending money on something you will be disapointed in.
Kyo
Apr 13, 2019 09:24 AM
Jutta_J
Mar 25, 2017 11:24 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
