cryo freezing seals??
Old Nov 5, 2007 | 04:42 PM
re-rx7's Avatar
Vp in charge of Girls
Are there any advantages to cryogenically freezing apex seals????
Old Nov 5, 2007 | 08:35 PM
RETed's Avatar
Why?
-Ted
Old Nov 5, 2007 | 08:48 PM
re-rx7's Avatar
looking into doing this process if it has any advantages to compression and or longevity.
Old Nov 6, 2007 | 02:02 AM
grimple1's Avatar
Turd Ferguson
it hardens metal. so yeah the seals should be harder and thus have increased longevity. It's pretty common to see piston guys with cryotreated cranks. Heck even musicians with metal instruments have cryotreated horns.
When metal is heated (as in forged, or molded, or whatever) the molecules are moving very fast. Even when the metal is hardened it can take YEARS for the molecules to slow. Cyro treating lowers the temperature and thus slows the molecules movements....the molecules are more compacted and near stationary.... thus the metal is more (for a lack of a better word at the moment) hard.
Old Nov 6, 2007 | 02:15 AM
re-rx7's Avatar
Might look into doing this and see how it works being that it won't cost that much for seals!
Old Nov 6, 2007 | 02:28 AM
certifiednut's Avatar
Mike Honcho
i would say this is a bad idea,,,, wouldnt making apex seals harder make them seat slower and also porentially tear up/wear your housings faster,
Old Nov 6, 2007 | 08:56 AM
TRISPEEDFD3S's Avatar
FEED me
Speed Machines Does this to their seals....
http://www.speedmachineperformance.com/
Old Nov 6, 2007 | 09:02 AM
R.P.M.'s Avatar
Likes to swear....alot
Just a thought as well....if I had some irons sent to a machine shop and had them mill them (lapped with a blanchard grinder), would cryro treating them be similar to nitriding them?
Old Nov 6, 2007 | 09:35 AM
Indian's Avatar
It wasn't me!!
What does this have to do with the "Turbo Section" how about putting this in the "Rotary Performance". You know where they talk about "General Rotary Engine modification discussions".
I'm not gonna tell you to search, cause chances are, you'll probably get that wrong too.
Old Nov 6, 2007 | 10:34 AM
Jason's Avatar
The one
If you want a harder/stronger seal then why not just buy one?
Old Nov 7, 2007 | 12:44 AM
re-rx7's Avatar
Could a mod please ove this to general rotary tech? thanx!
Old Nov 7, 2007 | 03:53 AM
RETed's Avatar
+1
Harden the apex seal...wear the rotor housing and the apex seal groove in the rotor.
There is no free lunch.
Longevity is not something you're going to gain from making a "stronger" apex seal.
Harder also means more brittle.
If the apex seal does fail (and it will under abuse), it's going to shatter into nice (hard) pieces...
-Ted
Old Nov 7, 2007 | 09:07 AM
KBSRX7's Avatar
no
I don't think its a good idea. This method is used to strengthen parts, but the breaking of apex seals is more of a shockwave even this wouldn't prevent. For all other parts ,do it. I think they should make 1/2" wide apex seals!
Old Nov 7, 2007 | 09:40 PM
Mike Honcho
if i remember right werent the 10as seals like 6mm wide i think,,, but most people dont have much trouble with highquality 2mm seals from what ive seen,, just tune better
Logan Reinisch
44
Sep 17, 2018 12:20 PM
