going single 1st timer
Old Nov 3, 2007 | 05:27 PM
7_7's Avatar
7_7
hey guys im finally made the leap and purchase a gt35r from aspec, i search alot lately and found some good build threads to aid my installation. i already installed the turbo kit but i need to know how to wire up my 1600cc injectors, and pretty much everything else need to get the car running
i have:
power fc btw
gt35r kit
rx7 store fuel kit (550, 1600)
any help or advice would be greatly appreciated
thanks
Old Nov 3, 2007 | 06:09 PM
diabolical1's Avatar
if you don't get much help here, you might want to try PMs or going to the A-Spec forum on the board. wish i could be of more use. sorry.
also, it would help to be as specific as you can with your questions. for example what exactly is the trouble with the wires? that sort of thing ... pics might help as well.
good luck.
Old Nov 9, 2007 | 12:29 PM
3rd Gen Jeremy's Avatar
Yeah if you have any trouble, I recently installed a new fuel system on my car so I can help you with it. 1st thing, make sure you wrap the teflon tape int he correct direction and only use it on the square fittings, not the tapered ones. Make sure everything is tight when your done.
You do know that you've got to remove your emissions and ACV right?
When you get done, prime the lines by jumpering the fuel pump and check for leaks. If you have a small leak, it can catch your whole engine bay on fire. Go slow and be very thorough. I did this and didn't find any leaks. I put it back together and ran it for about an hour and took the UIM off again. I looked really good at every fitting and as it turns out, I had a small leak that created a pool of fuel on the top of my engine. Glad I caught it or I would have barbecued my baby.
PM me if you have any specific questions.... I'll be glad to help.
Jeremy
Old Nov 9, 2007 | 04:50 PM
Smitter's Avatar
94 Single Turbo FD
u just have to cut off the grey clips off the wiring harness that go to the secondary injectors and solder the new injectors to the 2 wires...u should have a resistor in one wire aswell. shouldnt matter which one
Old Nov 9, 2007 | 09:04 PM
Eggie's Avatar
Originally Posted by smitter113fd
...solder the new injectors to the 2 wires...
Wow!!!
Old Nov 10, 2007 | 10:34 AM
7_7's Avatar
7_7
thanks guys just finished the install, but now the car has no cluster lights nor does it want to crank
my healights sunroof and sunroof works though
Old Nov 11, 2007 | 08:54 PM
could it be the main fuse? Did you short a circuit anywhere? Check your fuses.
Does it try to turn over?
Old Nov 11, 2007 | 08:58 PM
7_7's Avatar
7_7
i think thats it, but my main 120 amp fuse is good
no crank
will check on the fuses again tomorrow
Old Nov 12, 2007 | 10:17 AM
no crank
how did you wire the injectors in? Did you have the battery connected?
I blew my main fuse and I could have sworn up and down that it was good. I checked it twice and I think the light played tricks on me through the little view window. When I finally pulled it and looked at it in the sunlight, it was pretty clearly blown. Just an anecdote, hope you find it.
Old Nov 12, 2007 | 11:29 AM
7_7's Avatar
7_7
battery was off
1600cc injectors has resistors in it, still have stock 550s in the primary
just swapped the main fuse and still no dice
problem thread here
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/no-cluster-lights-no-crank-after-going-single-703285/
