Fujite Engineering Spec R oil
on
here is the pic, do you guys know this oil? is it good? here is description:
the -- running -- just -- for a Racing Spec. rotary engine -- engine heat -- a powerful enemy. Oil management is one of the very important factors. As a result of a severe test, the highly efficient oil which resulted in marketing promises the stable oil pressure, and removes powerfully the carbon inside the engine deposited although the aggressiveness of seals was low. In addition, heat-resistant high performance which does not deteriorate even if –ы‰· exceeds 150 degrees. Moreover, a change-of-the-oil cycle can also be lengthened because blowby gas also decreases that it is hard to atomize oil. The actual situation selling price of 9,450 yen . Kanto of 1160 yen which is cheap offer since a dent is in a can. If it is to the northeast of 1370 yen, Kansai of 840 yen, and Kyushu 950 yen 2 tin, it can send for the same mailing cost.
Everyone loves oppai =)
on
Never knew FEED had RE oil. Just out of boredom I was browsing the trust website and I never knew they had RE specific oil as well. They have a full synthetic and a half synthetic.
KAL797
Test Area 51
08-11-15 03:47 PM
