buying a turbo 2 need some info asap pls
Old Apr 11, 2002 | 12:59 AM
djsonic's Avatar
Newbie
yes i found a turbo 2 rx7 the guy said hes puttin a jap imported motor in it but his mechanic said its just a junkyard motor is there anyway to tell the difference between a japanese motor and an american one . and also he said it has that fuel cut defender , where would that be located so i can verify him, and also what boost should the car run under regularly. thanks
sean
p.s. if u can email the info to me id very much appreciate it thanks
Old Apr 11, 2002 | 01:03 AM
Ryde _Or_Die's Avatar
I am not positive on the jspec v. us spec motor but I am sure someone else will be. The FCD can be located in the passenger side engine bay and I believe down where the ecu is. About the boost level, it should boost to 5.5 psi for 87-88 and 7.5 psi for 89-91. Just depends which you are looking at.
Old Apr 11, 2002 | 01:31 AM
djsonic's Avatar
Newbie
thanks , also are there any common problems/rust spots i should check for
Old Apr 11, 2002 | 09:11 AM
Well if it has a sunroof, then look for rust bubbles there. Also they seem to rust in the wheel wells and when you open the hatch up the drain trough. Common problems are the 3800 rpm hesitation, flooding, most of the electrical(power windows, sunroof, wipers, antenna, etc) seem to go. Check the oil and see what it looks like, lookings at the condition of the dipstick and also the condition of the oil fill tube. Also on the boost, the stock gauges does not read in psi, its some weird ****. In the 87-88s it should go up to pretty close to 40 on the stock gauge. That means if the 89-91s have the same gauge they should go up to close to 55.
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
cam_7779
Aug 18, 2015 07:48 AM
