TII ran 14.07 @98.89 MPH
Old Apr 10, 2002 | 11:44 PM
vosko's Avatar
Just Call Me Terminator!
ran my TII found out the used upgraded turbo i put is doing the same thing my old turbo did puking oil but alot less than the old one anyway here is the timeslip
rt .636
60' 2.106
330 5.915
1/8 9.080
MPH 77.42
1000 11.796
1/4 14.076
MPH 98.89
now to decide if i want to go custom fmic and custom turbo upgrade
Old Apr 10, 2002 | 11:45 PM
vosko's Avatar
mods are
act race clutch
17lb flywheel
panspeed ecu
3" dp
3" mp
garrett upgraded stock turbo (exact size unknown slightly larger than stock)
cone filter
11psi of boost dropping to 6psi
Old Apr 10, 2002 | 11:52 PM
Scott 89t2's Avatar
SOLD THE RX-7!
get a dam catback!!
Old Apr 10, 2002 | 11:53 PM
vosko's Avatar
its enroute! just waiting for ups to deliver my used apexi n1 catback i'm also waiting for my greddy manual boost controller. i think my TII will soon have T04 turbo and fmic........
Old Apr 11, 2002 | 12:39 AM
Erik's Avatar
Best of both worlds
cool time...so you're keepin it?
Old Apr 11, 2002 | 12:45 AM
Ryde _Or_Die's Avatar
pss ::fuel:: (cough)
Old Apr 11, 2002 | 09:37 AM
vosko's Avatar
well i thought the engine was on the weak side but it turns out the upgraded turbo we put on had the same problem as my original one! i have no luck with turbo's
Old Apr 11, 2002 | 12:42 PM
Judge Ito's Avatar
Smile Vosko dont forget
Vosko don't forget the Rx-Truck ran a 12.40 @108mph with 9lbs of boost on street tires with a stock ECU....
Old Apr 11, 2002 | 12:44 PM
vosko's Avatar
that means were going for 11's on high boost
Old Apr 11, 2002 | 12:52 PM
SoloIIdrift's Avatar
Whats the word on the engine then, is it sick, or it's just the turbo's you've had?
Old Apr 11, 2002 | 01:34 PM
Grimlock's Avatar
if you ran a 14.07 1/4 mile then i should be able to tap into the 13's with the mods i got. wish i could tap into the 12's instead all in due time though
too bad with your luck on turbos--rebuild it dude?
Old Apr 11, 2002 | 02:11 PM
vosko's Avatar
the engine is fine the oil seal is going on the turbo we put on. i looked under the hood on the outlet pipe its dripping with oil...... i could send this to get rebuilt but if i'm gonna spend that much $$$ might as well get a custom manifold, external wastegate, yadda yadd
Old Apr 11, 2002 | 02:14 PM
vosko's Avatar
yeah 13's aren't that hard to do. best mod is to learn how to drive. i can squeek .07 out of my shifting probably. i have no luck so i come to expect stuff to break when its not supposed to. guess that's why i have 3 rx7's the first time you run your car you probably won't run a high 13 its gonna take practice. this is the sixth (i think) time i've gone drag racing with my car and i almost edged out the high 13 atleast my car has a better timeslip than my friends 240sx with sr20det. that's what really matters
snoopster76's Avatar
Twisted Girl Chaser
i need to learn how to get my 60' and 300' time down and i should be there too. good times.
Old Apr 11, 2002 | 05:00 PM
vosko's Avatar
adjustable shocks help alot in getting your 60 FT down
Old Apr 11, 2002 | 05:35 PM
kabooski's Avatar
Laying Down Rotary Law
a rebuild kit is like $110
My car was puffing mad smoke at high boost a couple of days before I blew some minor part(I have not opened the engine yet) still accelerates good ar high rpm
but low sucks
maybe the turbo went bad too
You sure in your case it's not a engine oil seal?
or maybe your oil pressure is too high?
Old Apr 11, 2002 | 05:40 PM
vosko's Avatar
i let the master - judge ito check it out. at the track i popped the hood outlet pipe of turbo was coated in oil. so its def the turbo not the engine. oil pressure is fine. i just have no luck. i'd rather it be the turbo than the engine anyway i'll find out real soon about what i'm gonna to make the car not smoke and go faster
Old Apr 11, 2002 | 05:49 PM
fastrotaries's Avatar
W. TX chirpin Monkey
I averaged a 14.01 and my personal best was a 13.93 with the same mods except the flywheel, but i did have a cat-back. My turbo was wayyy sick. So 13's shouldn't be that far off. Good luck. Remember..."focus on the moment"
Old Apr 11, 2002 | 05:52 PM
i mean 13's for you, because with my blown motor i would surprised if i can limp through the traps at 45 seconds. SOON to COME vengeance to all the redneck V8's in WEST TEXAS.
Old Apr 11, 2002 | 06:27 PM
vosko's Avatar
well on the track i'm gonna try and run 14psi when i have the catback and boost controller
Old Apr 11, 2002 | 06:45 PM
kabooski's Avatar
well not to brag you know
external Mods:
3" exhaust... period! = 13.5@105MPH@10PSI
you can ask Little Donny he has seen my car at the track
Plans are:
fix what ever broke in the engine and re-seal it
everything was new
run a aftermarket EMS
stock turbo
upgraded injectors
pump and reg
and run mid 12's jsut to prove ReTed wrong that you cant achieve sub 12's on a stock Turbo on a TII with no weight reduction
Old Apr 11, 2002 | 10:18 PM
Anderson's Avatar
external Mods:
Where ya been man?
OHh I think you forgot to tell them one minor detail.
You have your engine in an N/A body which is lighter
But still you only payed like $80 for the exhaust or something liek that right?
Or wasit $180?
Old Apr 12, 2002 | 12:01 AM
vosko's Avatar
this TII is going for sale soon. my FD will be ready VERY soon
Old Apr 15, 2002 | 10:50 PM
Manolis_D's Avatar
HOW soon?
Old Apr 15, 2002 | 11:59 PM
vosko's Avatar
a month or two
alexdimen
20
Oct 23, 2015 01:50 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
