fuel filter
Old Apr 10, 2002 | 10:59 PM
rx-7s rock's Avatar
Game of Death
Thumbs up fuel filter
where is the fuel filter located on the 2nd gen rx-7?
Old Apr 10, 2002 | 11:01 PM
damn hippies
i was told engine side middle ish on right on/by the firewall, if you find it tell me i havent had time to get at it
Old Apr 10, 2002 | 11:04 PM
Icemark's Avatar
Kinda below the brake master on the driverside framerail
Old Apr 10, 2002 | 11:05 PM
rx-7s rock's Avatar
Game of Death
I'll see if I can get at the little bugger. Thanks guys.
Old Apr 11, 2002 | 12:10 AM
dra_gon_lee's Avatar
hey man, you have to depressureize your fuel system b4 you mess with that...
Old Apr 11, 2002 | 01:05 AM
Ryde _Or_Die's Avatar
Its under the car by the drivers door. Like a few a foot or 2 under the car. It is a small black cylinder with a hose coming out of each end.
Old Apr 11, 2002 | 06:23 AM
damn hippies
how do you depressurise the fuel system?
Old Apr 11, 2002 | 06:30 AM
Felix Wankel's Avatar
Super Newbie
If you don't have a fuel cut switch, yank the EGI fuse while its idling and let it die.
Old Apr 11, 2002 | 09:06 AM
I didn't depressure mine when I changed my car and hardly any fuel came out.
Old Apr 11, 2002 | 03:11 PM
Super Newbie
Your injectors must be shot then.
Old Apr 11, 2002 | 03:13 PM
sunshine's Avatar
Yup, I didnt depressurize (cause I was a dumbass) and got my hair full of fuel as a result. Make sure to depressurize!
Old Apr 11, 2002 | 03:29 PM
It was in my NA and my car never flooded except when it sat for about 6 months straight and ran good when it ran, lol.
Old Apr 11, 2002 | 03:41 PM
hIGGI's Avatar
MaTeZZ got to taste some fuel when he was changing fuel filter ;o)))
Old Apr 11, 2002 | 03:57 PM
Cwaters's Avatar
Just Messing About
Anyone know if the bolts and bracket are included with a new filter? mine are kinda grungy.
Cory
Old Apr 11, 2002 | 04:38 PM
execelon1's Avatar
scathcart
I wish I was driving!
Re: fuel filter
Which one? The 100 micron ss mesh canister pre-pump filter or the 10 micron paper canister filter after the pump?
I'm special!
Sean
Old Apr 11, 2002 | 04:41 PM
execelon1's Avatar
Sean, did you get the pm?
Old Apr 11, 2002 | 04:43 PM
NZConvertible's Avatar
I'm a boost creep...
Wrong, that won't work! If you pull the EGI fuse the injectors stop working, so pressure remains in the system.
You need to unplug the fuel pump plug under the rear carpet while the engine's running so fuel keeps flowing through the injectors until the engine starves and dies.
Originally posted by execelon1
scathcart
you rang?
Old Apr 11, 2002 | 04:47 PM
yeah, replied too, check it out.
Old Apr 11, 2002 | 05:02 PM
Super Newbie
Do it the ghetto way and put some vice grips on the fuel line
Old Apr 11, 2002 | 05:28 PM
cash money's Avatar
Old School Member
hayes said just to unscrew the gas cap, i still got an ear full full of but i kept the line on the filter loosley until i got both ends off, it wasn't too bad
Old Apr 11, 2002 | 05:32 PM
That's to relieve any pressure in the fuel tank, not the fuel lines!
Old Apr 11, 2002 | 05:49 PM
AKABILLY's Avatar
I replaced my fuel filter like 2 weeks ago. The filter does not come with the bracket. Just use the same one and clean it off with some WD40, some of the paint will probably come off while cleaning it but, no big deal you can hardly see it from the engine bay. Since it sits almost directly under your brake master cylinder it's bound to get dripped on and look like ka-ka. Un-Plug the connection to your fuel pump like everyone has said near the base of the drivers side speaker tower under the carpet, while the car is running. Jack the car up and use jack stands for safety. I found it easier to remove the bracket with the filter still attached and then work on it. Make sure you have some rags cause that filter is going to be full of gas. You still may have gas coming out of the fuel line so vice grips will help. The filters have grooves on them so make sure they match up in the bracket or else you'll have trouble tightening the bracket around the new filter. And most importantly install the filter correctly with the "in" facing down toward the gas tank.
Old Apr 13, 2002 | 01:39 AM
RexRyder's Avatar
if i smell gas while driving could that be the fuel filter? I checked the fuel rail and puls. damper, no leaks and everything seems good. Sometimes the gas smell is so strong that my eyes begin to water. thx in advance
