FS- Rx-8 staionary gears, machined for >95 engines.
Collections Hold
I have two sets of Rx-8 staionary gears, as in (2) front gears, and (2) rear gears brand new from mazda. I had both rear gears machined to accept the OEM 79-95 O-ring. No need for trusting just RTV. Asking $200.00 per set (1) front (1) rear.
Collections Hold
Here are pics.
Works with 20b also. The tooth profile is supposed to be better, and they are made to handle high rpms. The machine work allows the standard rear o-ring to be used now.
Trending Topics
Collections Hold
$200.00 shipped for either set! This is the last time they will be up for grabs, or else I will keep them, and install in a future performance engine.
The machining I had done alone cost over $90.00 each to do. And these are most likely the only set you will find modified to fit in the older engines with the older O-ring.
Collections Hold
Collections Hold
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
joel(PA)
Race Car Tech
Oct 1, 2015 10:25 AM
