Slotted/drilled brake rotors
Old Apr 10, 2002 | 09:25 PM
82transam's Avatar
Never Follow
Yo, does anyone know if someone makes cross drilled and slotted brake rotors for non SE fb's? Peace
Old Apr 10, 2002 | 11:37 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
yep there is 2 places to get them. NOPI had then last year when i got them for my 81...got the hookup from a emplyee his price of 99.each for sloted about 210 for the set. they list for 193 each.
RX7.com has sloted and xdrilled for fbs.
Old Apr 11, 2002 | 10:28 AM
hanman's Avatar
Dont' bother, they are a waste of money.
just my opinion, I could be wrong,
hanman
Old Apr 11, 2002 | 11:34 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
they look cool but yea, not worth the price diffrence
Old Apr 11, 2002 | 03:34 PM
Redwood's Avatar
Find Racing
Slotted and cross-drilled rotors are definitely a waste, unless you don't have vented rotors. Both of these additions are left over from the good ol' days when vented rotors were just a dream. Since you're driving a car with non vented rear rotors, you could buy cross-drilled or slotted, but it would be wiser to just upgrade to the SE brakes. Vented rotors without any holes or slots will outlast a rotor with vents or holes anyday.
Oh, unless you're talking about racing in CART or IRL, in which case you do want slotted rotors. But if that's the case, there's probably other upgrades to assess first. Later.
Old Apr 17, 2002 | 06:30 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Correct me if I'm outta line here... I could be wrong, but as I understand it, slotted rotors have nothing to do with cooling. The slots on brake rotors are supposed to collect the brake dust and keep it from building up under the pad, right? That prevents fading over long braking periods...
Cross drilling however is just to help cool things down, and probably IS a tad redundant with vented rotors... unless you race (or at least are very hard on your brakes)...
Old Apr 17, 2002 | 06:35 PM
riffraff's Avatar
smog nazi destroyer
that is correct smnc
Old Apr 17, 2002 | 08:23 PM
JIMMY54's Avatar
GSL-SE PRO
One of the other reasons i decided against it was that since our rotors are small to begin with when looking through my rims, if i were to get drilled rotors it would only look even smaller and thefore would look worse to me..
Old Apr 17, 2002 | 09:59 PM
mar3's Avatar
Administrator
Actually, that is wrong, riff 'n smurf...both designs are there to prevent gas pressure from lifting the pad away from the disc when super-heated. The cross drill was first and slotted came along later when poorly done cross-drilled rotors started failing on street cars. When pushed to the limit, even undrilled vented composite rotors will fail as any F1 tifoso can attest to. I'm running cross-drilled rotors done by a competent metallurgist/machinist that have seen continuous hard street duty for 4 years and counting. They eat up pads like a bitch but there is no fade and there are no signs of cracks. The holes aren't even chamfered.
Old Apr 17, 2002 | 10:02 PM
mar3's Avatar
Administrator
They are, however, puny looking....if peejay would ever get his entrepreneurial juices going, I'll buy a set of big rotors and 6-piston calipers for the '80 strut set-up...that's worth about $500 to me...
Devon300zx
15
Sep 16, 2015 06:57 AM
Frisky Arab
Sep 4, 2015 06:17 PM
