super angle kit install help
Old Oct 21, 2007 | 01:38 PM
CyborgRyu's Avatar
Drift FC
http://mazdatrix.com/pictures/racing...ingAngle1w.jpg
i have the g-master version of this (GP Sport) kit and Im wondering what the 2 seperate pieces of this kit is for?
Old Oct 21, 2007 | 06:47 PM
eyecandy's Avatar
I guess you are not all too firmilar with the kits function. I can help you out, I import the Super*Now kits they are all identical to G-Sports and Mazdatix which they both stole Super*Nows design.
What pieces are you talking about?
The outer tie rods should be self explaintory, they are bumpsteer adjustable with the 5 and 10mm spacers. The other two pieces thread onto the steering rack, you remove the inner tie rods bolt the threaded adaptors on, then bolt the inner tie rods into the adaptors. Before you bolt the inner tie rods back into place you need to cut up to 1cm from the outer end, other wise you will have too much toe out. I am working on some oem replacement inner tie rods that do the same as the kits, but no cutting, just a direct swap.
astrum
24
Nov 15, 2017 08:44 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
